Results 1 to 4 of 4
Thread: Fuel pressure Gauge location
    Default Fuel pressure Gauge location
    G'day
    seeing as i have fabbed up my own fuel rail im trying to decide where to locate the fuel pressure guage as my FPR is adjustable
    Here is a diagram (attached) of how i was thinking to mount it, would this work or would i have to mount it before/after all the injectors?
    It should work like that its just i dont have alot of room between Fuel rails firewalls and brake MCs etc
    Any info on Pressure gauge location would be helpful
    Penrith BC
    Default Re: Fuel pressure Gauge location
    doesnt matter really - pressure should equalise
    does the FPR have an acc port for a gauge?
    ../delete/ban
    tech moderator
    i'd suggest mounting the FPR on the firewall or guard-arch.
    Things like malpassi's are alleged to fall apart from excessive vibration, and some guy on performance forums had an alloy part on a rail-mounted FPR crack while driving resulting in major engine fire to a genuine sierra-cosworth-turbo.
    ALso, there's no fuel-flow requirement to have the FPR attached to the fuel rail and most have two inlet ports - one taking fuel from the rail, the other to suit a guage.
    FPR goes after the injectors (e.g. tank->pump->filter->rail->fpr->tank).
    Pic of how mine is mounted on firewall:
    Mine has only one inlet/outlet so i guess i will just whack on a T peice
    The idea of mounting that was was to try to save some dollars on speedflow fittings, although it looks like i may be sticking to conventional tubing now so it may not matter
    Rohan
  1. Can an oil pressure sensor be used for fuel??
    By amichie in forum Tech and Conversions
    Last Post: 30-06-2006, 11:38 AM
  2. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
  3. engine pinging
    By HAVABEER in forum Tech and Conversions
    Last Post: 15-12-2005, 12:15 PM
  4. Replies: 1
