Results 1 to 15 of 30
Thread: MA45 Axle
    jimmya Grease Monkey jimmy_a's Avatar
    Default MA45 Axle
    Howdy
    So....i bent the left rear axle in my ma45, 81 Celica XX. Sigh.
    It's got a T series dif, with discs.
    Firstly...will the axle off a ta22 fit it? They're drum rear, so i wasnt sure if they would be the same or not. I have access to one.
    Secondly...if the ta22 axle doesnt fit, what will fit? RA40/RA60 axle?
    Also, what dif swap can I do? I know a G-series will bolt straight in, but it's a matter of getting one - il start looking, if by any chance the axel off my ma45 is one of a kind.
    Thanks, James
    Quote Originally Posted by blacktopspirit
    Gastro has hurt me for 4 days now! want to die! to scared to fart, to scared to eat, to scared to be more than 4 meters away from toilet!!!
    Default Re: MA45 Axle
    I'm pretty sure the RA40 axle is the same width; it's more or less the same chassis so it stands to reason.
    There's no way a G series diff will "bolt straight in", not until you've cut the suspension mounts off it and welded on the MA45 mounts. But that applies to any diff really.
    also modded the tailshaft too...
    MA46's had G-series LSD's in them, i have been told a G series will bolt straight in??
    Sigh. Why do I have to have a rare car. Of course a g-series wont bolt straight in, different suspepnsion. The problem with just any g-series dif is the ratio
    So about the ta22 axle?? Or does anyone know where I can find a wrecked RA40?
    wreckers probably isn't a bad bet. there is two @ Harvey's in Baxter last time I went.
    Are RA40's disc or drum rear?? And is that going to make a difference?
    Some MA4x's have an F series diff, NOT G series.
    And yeah just about every wrecker I've been to recently had at least half a dozen RA40's, you shouldn't have a problem finding one.
    ra40s are drum rear.
    mmmm i thought they were G series???
    Now do Cressida's have F series as well? If so...can i get the lsd dif out of a Cressy and put it in mine? Without any overly exorbitant hassle + spending?
    RA40s are wider rear end as well. They are about 1350mm, as opposed to the 1320mm of the TA22.
    Some Cressidas (eg MX73) have an F series diff but they're also IRS, hence of no use to you.
    Basically your only plug-and-play option for a bigger diff is the F series found in MA46's, and good luck finding one of them. Apart from that you're looking at a full-blown rear end conversion.
    User Conversion King
    NWA
    on that note, RA60 and RA40 diffs are identical in every way. all RA60 diffs have sway bar mounts, however only the very late RA40's have sway bar mounts.
    same width.
    hello
    Quote Originally Posted by brett_celicacoupe
    except for the diff its self, which is a different ratio
    The MA45 axles are totally different to anything else.
    I would recommend getting your bent axle straightened. Easy and cheap, well, until you replace the bearing - you might get it all done for under $200. Take it to a diff place if you're not confident doing it yourself.
    Also needing my torque wrench.
  1. FYI Rear Live axle configuration RT104GT
    Last Post: 31-08-2006, 06:41 AM
  2. Cause of axle leak?
    By RobertoX in forum Tech and Conversions
    Last Post: 20-08-2006, 12:56 PM
  3. MA45 - GA45 engine conversion
    By jimmy_a in forum Engine & Driveline Conversions
    Last Post: 04-08-2006, 04:43 PM
  4. AE86 Axle upgrade needed...
    By irishtwincam in forum Tech and Conversions
    Last Post: 07-03-2006, 06:19 AM
