Results 1 to 8 of 8
Thread: brake rotors
    W.A
    Default brake rotors
    What toyota cam with freewheeling brake rotors the type that are not mounted to the bearing hub and are four stud and will fit inside 13inch rims
    Default Re: brake rotors
    i think you'll find that all RWD small toyota (e.g. 4-cyl) brake rotors bolt to the hub rather than disk-over-hub.
    As for FWD, someone else can pipe in.
    DBA catalogue should be useful for you, go to www.dba.com.au and have a look.
    Aug 2006
    The SV21's have the rotors on the front that slide off once the caliper is removed.
    Not sure about the rear rotors as I've never touched the rear brakes on ours...
    One other thing, they are 5 stud. PCD 5/100.
    toyota starlet EP91 are slide over hub 4 x 100 and fit inside a 13" rim, maybe also some of the earlier rollas, ie AE82?
    Aug 2006
    success 6164
    my ae82 front and rear are the over hub type..they should fit under 13 inches aswell..
    Low spec ae92s as well (ie cs, csi etc not sx/gti as i don't think they fit under 13s)
    Toymods Club Member
    Junior Member Backyard Mechanic M.J.H's Avatar
    Quote Originally Posted by damo101
    They do with the std steel wheels so should be okay.
    By The Witzl in forum FAQ
  2. Disc Brake conversion of Live Axle RT104 RA40
    Last Post: 18-05-2011, 03:50 AM
  3. break upgrades/ta23
    By buztoy in forum Tech and Conversions
    Last Post: 14-10-2006, 09:00 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
