4age's use T series box AFAIK.
a340e's I have seen with J,M and G series bell housings. So no, will not bolt on.
Also, the E designates electronic so you will need an MV shift box to manualise it otherwise you will shift 1,3,4.
The line pressure is from the cable on throttle body for most older type a340e variants.
Stock boxes usually good for around 220rwkw and the associated torque from a 1jz-gte. So unless you are a nutter, it should last behind a 4agte (if you can mount it there?)
Size as in diameter? If so, search. Big thread with pics and all about 2 months ago.
*edit - just saw you said a40. Never even heard of one? *
