Results 1 to 15 of 18
Thread: fitting auto
    Banned Grease Monkey
    vic
    Default fitting auto
    just got a a40 3 speed auto for my 4 agte do they bolt straight on? how much power do the hold? do they run off vacum or cable? and if anyone knows what size stall converter is the standard one?
    Default Re: fitting auto
    4age's use T series box AFAIK.
    a340e's I have seen with J,M and G series bell housings. So no, will not bolt on.
    Also, the E designates electronic so you will need an MV shift box to manualise it otherwise you will shift 1,3,4.
    The line pressure is from the cable on throttle body for most older type a340e variants.
    Stock boxes usually good for around 220rwkw and the associated torque from a 1jz-gte. So unless you are a nutter, it should last behind a 4agte (if you can mount it there?)
    Size as in diameter? If so, search. Big thread with pics and all about 2 months ago.
    *edit - just saw you said a40. Never even heard of one? *
    QUICKEST 1JZ'S IN OZ
    3 speed? the a340 isn't three speed, so what on earth could it be?
    Facebook | LinkedIn
    I actually read it as a typo. a40 3 speed. Insert 3 into a40 to get a340
    Apparently the a40 is a 4 speed. Well someone who answered one of his questions before said it was?
    The most common auto box found behind 4A's in RWD format are trimatics.
    No idea what an a40 is?
    A40 was the 3-speed auto used in early Celicas, eg RA23.
    vic
    i was told the 3 speed autos in a ae71 is a straight bolt on to a 4agte which is a a40
    According to this thread : http://www.toymods.net/forums/showthread.php?t=7481
    the locally delivered AE71 had the trimatic.
    The jap spec/JDM ones would no doubt have had another model of auto box, perhaps the A40 you speak of??
    What ever box it is you have though if it came out of an AExx model it will bolt to a 4A.
    damn, what happened to your rep?
    Facebook | LinkedIn
    vic
    how much power do they hold?
    Trimatics can be made to hold quite a bit of power. They used to convert them to run behind VL turbos....until they kept breaking
    vic
    am i able to use the fly wheel of the 4a out of the ae71 or could i use the one i have ? the one i have is for a manual are they different??
    Junior Member Backyard Mechanic M.J.H's Avatar
    Quote Originally Posted by rollin
    No you can't use a flywheel with an autobox.
    You will need to get the proper flexplate to suit the motor and box you are using.
    My sig has been pruned as it was over 5 lines long.
    if it where a fwd eng/trans set-up a A241E 4 speed auto from a V6 camry will bolt up to the 4ag block.
    strong as shit and basicaly use E51/E58 gze size/type driveshafts.
  1. my SC14 fitting guide
    By Adsport in forum Tech and Conversions
    Last Post: 06-01-2011, 12:04 AM
  2. jzz30 auto to manual conversion
    By RIPSIP in forum Engine & Driveline Conversions
    Last Post: 08-06-2006, 07:08 PM
  3. Replies: 24
    Last Post: 18-04-2006, 02:42 PM
  4. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 07:15 PM
