Results 16 to 27 of 27
Thread: w55 jumping out of 2nd mid-drift
    Tallahassee, FL USofA
    Default Re: w55 jumping out of 2nd mid-drift
    The ball bearing & spring that push on the shift fork shaft's notch are there for positioning the shift fork, but don't 'hold it in gear' at all. That's really the teeth/dogs on 2nd gear and/or the teeth on its syncro hub job Yours are worn and have a slight taper that'll push it out of gear when loaded.
    I'd be fucking amazed if different oil did anything, and would sure like to know why!
    Most are cut straight, and some are even undercut with a reverse taper
    that will make it very difficult to pull out of gear when there is any load at all on it.
    Try pulling it out of gear without using the clutch when lightly cruising and when accelerating/decellerating & feel the difference.
    Well there are two testimonials here saying oil changes fixed this prob ... depends what
    the prob really is inside the box i guess.
    1ggte f series diff - suspension is the plans Dori ... motor should be in by end of JAN
    Black Betty >HERE!<
    (\__/)
    Junior Member 1st year Apprentice DORIGTRA23's Avatar
    south australia
    ALLENCR thanx very much for that, A ppg full internal gearset would be the way but at $4000 i dont think so, Should i see if i can get 2nd recut with the reverse taper?
    TA-022 Sweet man u using 86 suspension?
    (\_ _/)
    (")_(")TEAM TOUGE EST.2005
    18RG RA23
    3TC KE30 (DORI BEATER)
    CA18DET S13 (BEATEN LIKE THE BASTARD NISSAN IT IS)(MATES CAR)
    south australia
    OH CRAP The gearbox filler plug is round someones rounded the shit out of it time to pull out the box. FUN
    (\_ _/)
    18RG RA23
    Quote Originally Posted by DORIGTRA23
    BZZZ, wait a sec before you pull the box...
    If the drain plug is OK, then drain the oil...
    Take the center console and shifter out and fill the gearbox via the shifter hole (measure the correct amount of fluid).
    Unless you really want to remove the gearbox? lol
    Victoria, Mt Macedon
    Or get a spare filler plug from a wrecker/your spare box/any bolt that fits, then remove rooted filler plug with vice grips. Fill box and then fit new, good plug.
    And then stop endorsing street drift.
    Hen
    south australia
    WILBO cheers that would save me a headache any ideas on how much fluid a W55 takes?
    HEN yea ive sorta got the idea bout that
    (\_ _/)
    18RG RA23
    http://www.datateck.com.au/lube/valv....asp?section=1
    2.5L apparently
    or even weld a nut onto the end of the filler plug.
    whys everyone so uppity to remove gearboxes, its such a PITA
    south australia
    + rep for love ke70 you champ good fkn idea
    (\_ _/)
    18RG RA23
    Not as much PITA as it is in a fwd but we wont go there....
    mm, lets not
    ive spent today pulling an oil pump out of a fwd, in the car....so not cool
  1. Drift Comp 15 April With SA Cars/Drivers
    By Endless in forum Western Australian Events
    Last Post: 18-04-2006, 11:23 AM
  2. WA Drift Night
    By Pr0j3kt_SuPrA in forum Western Australian Events
    Last Post: 15-04-2006, 06:47 PM
  3. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
