Results 1 to 4 of 4
Thread: closed loop boost controllers
    Default closed loop boost controllers
    i see the new Haltech piggyback computer has abuilt in closed loop boost controller
    i am of the impression that htese work out the duty cycle to make the boost come on faster, is this correct
    i have found this new one on the market, has anyone heard of it
    http://cgi.ebay.com.au/HDI-EBC-FOR-S...QQcmdZViewItem
    The boobs are back
    Default Re: closed loop boost controllers
    G'Day mate,
    Closed loop boost controllers measure the actual boost pressure and then adjust the wastegate to suit (i.e. if the boost is low it will close the wastegate, if its high it will open it), it will continuously monitor the boost level and adjust the wastegate to suit. The EBC determines the required duty cycle of the solenoid by looking at the actual boost and comparing it with the target boost level (set by the user) and then it goes through some calculations and gets a duty cycle which it then applies to the solenoid.
    I havent heard of the boost controller in that ebay ad so i cant help you there...
    so does it work out the duty cycle to make it boost faster
    The boobs are back
    Not necassarily, most of the systems on the market today rely on the user to set it up with the correct gains (this will determine the boost response). Once the gains are set the boost will respond pretty much the same every time.
    A self learning EBC will actively tweak the gains in order to increase the boost response, im not sure which have this feature though.
  1. What ECU do you use?
    Last Post: 06-12-2007, 10:42 AM
  2. 1JZ- how to tell it's going into closed loop?
    By BigWorm in forum Tech and Conversions
    Last Post: 13-09-2006, 09:21 AM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. Boost Leak Tester
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
