Results 1 to 15 of 16
Thread: 7m inlet manifolds
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default 7m inlet manifolds
    I just interested to know what difference you would see on a 7m between a cressida inlet manifold and a supra one?
    Nice ****** Grease Monkey rvrolla's Avatar
    Default Re: 7m inlet manifolds
    Someone off the Cressida forums has tried this, apprently it is not worth the time, hassle and most of all cost.
    Youre talking NA to NA right? I wasnt aware there was a difference....
    There is
    MA70
    MX83
    Well there you go, I learned something about N/A p00
    Act
    N/a Crowns also had the Y set up. I had one out of 7M crown in my MS53 it turned some real good numbers.
    I didn't think that it was supra vs Mx83 more early verses late series. I though some of the early MA70 still had the T duct.
    Also I think the Y set up engines also have different AFM. As mine didn't have a flap.
    Quote Originally Posted by TheStitt
    Dunno I've seen at least 2 86 MA70s with the Y style...
    penrith nsw
    ok, i am in the process of buying a non turbo piece of poo for my mx73 as my 5mge now seem to have an oil consumption problem. I want to get as much power as possible on a budget, being a family man and all, i thought this may have been a option for improvment.
    Im planning on just doing a full rebuild with a nice exhaust and and intake is the plan so far. Im going to pick up the motor from Rod on monday hopefully so i can make a start on it. I think if i can squeeze 100rwkw out of it i will be happy.
    i have also noted that the 1j uses a y type inlet as well.
    Im happy to take on any suggestions for building one of these motors.
    Cheers pete
    possibly acis? or some variation of variable inlet runner length? Can't see there being a big difference between them.
    They make over 100 rwkW in standard form. If you get less, you'll have done something wrong.
    The Y pipe one has a butterfly in the intake plenum - works to modify the inlet runner length to enhance torque at lower rpm. The system is known as Acoustic Control Intake System (ACIS). If you get that plenum, make sure the 7MGE ECU you use is able to run the VSV that activates the butterfly.
    The Crown 7MGEs (130 series) have a Karmann Vortex style AFM rather than flap style. Other thing is the Crown ones inside look a bit different to the standard Aussie fare. Cambelt pulled one apart - def had higher comp pistons and head was different too. Probably why yours pulled great numbers Stitty.
    penrith nsw
    what sort of numbers did you get out of yours stitt?
    Montrose
    I've got a 1986 magazine with a photo of a 7MGE Supra that definately has ACIS, and I own a 1990 MX83 that has no ACIS. So I don't vote for early/late.
    Quote Originally Posted by pete05
    107 or 108rwkw if I remember right
    Act
    108.7 or 107.8 rwkw. (A little less than rona)
    Thats stock with 2.5 exhaust and a pod filter.
    I was really happy with the driveasbility of it and it seemed to rev real well to.
    I'll try and get JesseT18 into this thread as that is were my engine now lives
    penrith nsw
    cool the more info the better, sadly my 5ge only revs to about 5g before power falls off drastically and with the 4.11 diff its a bit sad, so im hoping with a fresh 7m i should be able to squeeze some more revs out of it. how hard do they rev?
    Also any ideas on a optimum size exhaust for this engine, i was thinking of going 2 1/4 to try and retain some torque.
  1. gas research LPG carb and 5S-FE inlet manifold
    By splatt in forum Tech and Conversions
    Last Post: 20-10-2006, 02:32 PM
  2. 7m and 1g injectors?
    By hypo23 in forum Tech and Conversions
    Last Post: 05-10-2006, 01:28 PM
  3. 4AGE small port --> making the ports smaller again
    By 92-GTI in forum Tech and Conversions
    Last Post: 09-03-2006, 02:51 PM
