The transducer in the sensor is different. (Or I would expect it to be different given the pressure range mapped to the 5V voltage range).
The transducer effectively measures the difference between two pressures - in the case of absolute sensors one of the pressures is a vacuum reference of a certain value compared against the pressure of choice.
The 2JZ sensor went from somewhere around -10PSI (either 0V or as close to 0 volts as it could get) to somewhere around 17.5PSI (5V or as close to the supply voltage as it could get).
The main reason for using a sensor of a certain range is resolution. The higher the range, the smaller the voltage change for a given pressure change.
There is little point using a 2 bar absolute sensor for atmo engines (extreme example) as only half of the range of the sensor would be utilised - but in theory it should be cheaper, because you double your usage for one particular part number. The same theory follows for a 12PSI vs a 17PSI sensor - if the engine is not designed to run outside of the range, then the sensor doesn't need the extra range.
Given that pressure sensors can be had cheaply in any (stepped) pressure range you may desire, I have no doubt that Denso can get *any* specific range they want custom made in the 20,000+ runs of exotic engines with no price penalty. Denso already has microcontrollers made to their specifications at the packaging level - the silicon die, in some older micros, appears to be rotated 90 degree inside the resin casing to make sure nothing off the shelf will replace it.
The other aspect you mention - ECU firmware - might not yeild the benefits you suggest. If an ADC has a 5V range, using the entire range gives the best resolution for engine mangement. Obviously you could just use a 2.5V chunk of the range and then scale the result in software, but you have lost half of your resolution. You could also scale the 2.5V back up to 5V in hardware, but that will attract extra costs that could easily be avoided by using a sensor with the correct output range.
Thoughts?
Mos.
