Results 1 to 15 of 19
Thread: Is this a/f gauge worth having
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Default Is this a/f gauge worth having
    I am a little bit concerned with the limits of my ecu/afm with more boost added and was wondering if this narrowband gauge would be worth having to keep an eye on the a/f ratio.
    car is gen2 3sgte mr2( the wideband gauge is a little bit too expensive(US$379)
    Narrowband gauge
    http://www.autometer.com/cat_gaugede...id=3083&sid=11
    Wideband Gauge
    http://www.autometer.com/cat_gaugede...id=3604&sid=11
    The wide band gauge is a bit out of my price range but obviously better
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    Default Re: Is this gauge worth having
    NB guage only good for you at fast/warm idle and cruising - at any other time it'll just show lean or rich but not the actual AFR.
    Get a wideband O2 kit - fwiw, i'm getting an Innovate Controiller and a wideband sensor of these from the states (but without the dinky guage as it's being connecting to my ECU). Tech edge in Australia sell their own wideband kits - built and loose in kit form.
    See
    http://wbo2.com/
    and
    http://www.diyautotune.com/catalog/w...tems-c-23.html (US prices)
    for more info
    Tasmania
    Thanks for the info.
    Narrowband is obviously just a waist of time and money then. (unless you want rice lol )
    What's your thaughts on the autometer wideband gauge? Seems a little cheaper and less complicated than the the ones you suggested.
    I am also looking and getting boost gauge and oil pressure aswell in the same series.(trying to keep all gauges similar)
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    2008 VDJ200 Sahara
    User Conversion King
    NWA
    you might be better off buying a injector duty cycle readout from jaycar and keeping an eye on that.
    if it gets anywhere near 100% you might be starting to push the limits.
    wideband would be the best though if you can afford it
    hello
    Roflcopter Pilot Backyard Mechanic thu187's Avatar
    That sounds alot easier to follow
    What measurement is AFR measured in btw?
    [T]echnology is the only [R]eplacement for [D]isplacement
    NWA
    stoichiometric ratio
    moles air:moles fuel
    hello
    Tasmania
    Do you have a part number or something to help me find this readout/kit?
    Wideband would probably be best though i guess soon as i am contemplating ecu upgrade anyway.
    any thaughts on bang for buck for an ecu and/or wideband for 3sgte geatly appreciated (the cheaper the better )
    I'm a tight asse
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    2008 VDJ200 Sahara
    NWA
    Default Re: Is this a/f gauge worth having
    http://www.jaycar.com.au/productView...Max=&SUBCATID=
    if that link dont work, search the jaycar site "duty cycle"
    hello
    Tasmania
    yep thanks i found that but was not sure if that is what you were talking about or not.
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    2008 VDJ200 Sahara
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Injector duty cycle isnt always going to be best way of gauging whether youre AFRs are safe though. Same duty cycle can be lean or rich depending on what boost youre running (especially if the ECU doesnt know what boost youre running)
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    i bought an Innovate LC1 wideband meter for $270ish not that long ago, no gauge but u can buy an optional gauge for about the same again or there is an article on the innovate website about using a rice meter AFR gauge with the analogue output to give u real AFR readings
    also use the PC to log AFRs nicely and can use 1 of the 2 analogue outputs to simulate a narrow band for the ECU if you are still on a stock ECU
    btw, innovate website = www.innovatemotorsports.com (i think, from memory) and dealer in brisbane is Buzz Engines in Sumner Park
    i got an innovate wideband meter sensor and the aux kithavnt had much time to test it all but all up cost around 800
    u dont need the aux kit so should only cost about 500
    a dyno will cost around 200 to 400 so i think its cheap
    but if your running a std ecu what will you do with the meter
    if the std ecu cant cope and u see on yr expensive meter the mixtures are out what are you goin to do
    you cant really return yr std ecu and get better performance and still have good cruise and fuel economy
    i would only purchase one of these if your goin to play with aftermarket ecus
    if yr worried about mixtures with a std ecu just get a dyno run
    or speak to someone who knows 3sgtes
    If you import a sensor and the 'controller from the US - it will cost you about $235 USD before it arrives at Oz customs.
    (From my order showing US$ prices)
    1 x Innovate LC-1 Digital Wideband Controller with Sensor (wb-lc1-3769) = $199.00
    United States Postal Service (1 x 2.19lbs) (Global Express Mail (EMS) (3 - 5 Days)): $34.65
    I ordered thru http://www.diyautotune.com as Buzz are out of stock atm.
    The gauges is little more that dash-eye-candy so i never even considered getting one - mine was specifically bought for on-road tuning (and any logging i'll do via the ECU anyway) so it's just an LSU4.2 O2 sensor and small lump of silicon/plastic to control the sensor and pump out signals to a serial port and 2 outputs.
    (sorry for the uber-big picture)
    Mine is plugging into a msextra.com ECU and it can use wideband or narrowband sensor input from a few controllers.
    vic
    what about the jaycar $15 kit , it gives a basic indication , great for cars on lpg , a quick check to make sure u dont have a lean out
    Dave
  1. Temp Gauge Problems
    By Ghostrider in forum Tech and Conversions
    Last Post: 12-09-2006, 06:55 AM
  2. Turorial : how to install a gauge in z20 soarer in aircon vents
    By GU11TY in forum Tech and Conversions
    Last Post: 03-07-2006, 08:35 PM
  3. AE92 with silvertop gauge issue
    By deaf_rattle in forum Tech and Conversions
    Last Post: 15-03-2006, 03:11 PM
  4. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  5. Gauge repair 101 for 40 series Crowns
    By gianttomato in forum Tech and Conversions
    Last Post: 01-02-2006, 10:11 PM
