					 replacing the inside window trim on an RA40 replacing the inside window trim on an RA40
							Has anyone worked out a place or item to get a replacement of the felt window guide that goes along the length of the inside trim of the door.
 I tried Rare Spares today but they can only get ta22 ones and even then they will cost the better part of 70 dollars a side.
 Has anyone managed to get theirs replaced with a new strip, i am not too worried about the chrome bit as that looks a bit dated anyway and if a piece of plastic could be sourced instead i believe it would look neater.
 Is there a place where you can buy the stuff in lengths and cut to your desired width?
 the wreckers don't seem the go either as all tthe models i have seen the felt has been worn away or the rubber strip that pushes against the glass has cracked and become brittle.
 surely someone has replaced theirs, anyone???
					 Re: replacing the inside window trim on an RA40 Re: replacing the inside window trim on an RA40
							surely you have found out something Brett_celicacoupe?
							hmm ,
 still not sure what bit your talking about... is it the weather strip or the on the door card??
 if your talking about the weather strip then no, i havent replaced mine.
 i chose cure rather than prevention, i got some tectyl rust preventative wax stuff and used 1/2 a can per side inside the doors so the water can happily run over that instead of rusting the metal.
 so yeh - NFI where to get them from. tried genuine i take it?
 mine  arent to bad....out of the 5 RA40's ive owned in the past 2 yrs, ive picked the best bits for the blue one
		- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
