Results 1 to 6 of 6
Thread: How to test a g-series lsd
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default How to test a g-series lsd
    Just picked up a g-series lsd diff. Wandering if there is a way of knowing if it's an lsd with it out of the car.
    Mark
    1994 GZX90 Mark II 1GZ-FE V12
    south australia
    Default Re: How to test a g-series lsd
    turn one axle and watch the direction the other turns. if they turn the same way, then LSD. if turns opposite then non-LSD.
    you can also get some one to hold one axle, if you cant turn the other, thats LSD. if you can then non LSD
    Junior Member Backyard Mechanic SIKTOY's Avatar
    If the clutches are warn it might not lokc up pull the center out and see if it has clutch pack or just spider gears that the only sure way to tell
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    cheers for the feedback guys.
    User Conversion King
    NWA
    Quote Originally Posted by slide86
    errr, have you ever tried this with a torsen LSD?
    doing the above wont tell you anything if its a torsen
    hello
    Yup. If the diff is out of the car it's easy to take the rear cover off, then you can tell for sure what's inside.
  1. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:51 AM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
