Results 1 to 15 of 28
Thread: Square or round tube?
    Default Square or round tube?
    We have to replace the trailing arms on the rear suspension on the racing car, as one of them bent very badly under compression last weekend,
    My question is that for a set size (say, 30mm) what would be stronger in terms of resisting being bent, a 30mm diameter round tube or a 30mm to a side square tube?
    And how much more would the square tube weigh?
    Same wall thickness for both tubes.
    Penrith BC
    Default Re: Square or round tube?
    the square tube will be stonger but 27% heavier
    note: term 'stronger' is axis specific
    ../delete/ban
    tech moderator
    Penrith BC
    bill, you should clarify actually - was the original failure 'bent' or 'compressed'
    ../delete/ban
    tech moderator
    im too tired to calculate it, but I would say Ed is on the money.
    some reading:
    http://en.wikipedia.org/wiki/Second_..._cross_section
    and here is some in german.
    http://de.wikipedia.org/wiki/Fl%C3%A...A4gheitsmoment
    technically, if you use a rod end at each end it should be in pure compression, but if there are any irregularities in the tube at all it will kink or buckle.
    I would tend to use round as it will be symmetrically loaded, and for a given mass it should be stronger.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    the pics suggested it was bending
    Wouldn'ta rectangular section be preferrable? With the longer side vertical, Would be in keeping with OEM designs I've seen, though mostly front radius arms have been sq/rect and rear trailing arms round, and upper rear arms sq/rect.
    The only alloy rear arms I've seen were made from 2 x rect sections welded to make a sq section.
    Friends
    Penrith BC
    without getting too techy or mathematic about it - the shape that has the greatest quantity of material, where you need it, wins
    in pure bending, you want material perpendicular to the load, with the location of the greatest quantity of material (as in an I beam) in tension/compression as far away from the rod/tube's centreline as possible - so the box section wins. if you wanted to be even smarter, youd pick the primary load axis and get a rectangular section
    in longitudinal tension/compression, just the pure increase in material quanity that you achieve with a box over round - wins. as mentioned just be careful of dents/imperfections
    torsional loads - intuitively (for me anyway) a tough one in this comparison
    ../delete/ban
    tech moderator
    pics? pics would help, but my money is still on using round tube, unless it needs to fit through a square gap 31mm wide
    www.vicdrift.com
    Penrith BC
    round is a very material and weight efficient shape. it is also good for non axis specific loads
    if youve got a specific problem though, you have the opportunity to pick the right shape
    how many motorbikes run round swingarm main stays?
    how many roofing main members are round?
    how many square profile arrows do you see?
    we still dont know bills specific installation, or the details of the failure, so were all pissing in the wind a bit here
    ../delete/ban
    tech moderator
    i agree ed, but it is more fun than just sitting around.
    as for torsion, circular is intuitively the best for this reason:
    no other shape will get more material further away from the neutral axis, to bastardise your comparison, how many tailshafts have ypu seen that have not been round?
    www.vicdrift.com
    Penrith BC
    ah, yes, but first imagine the shaft didnt 'spin' but was just twisted...
    now make it bigger, 27% heavier, and square - would the round still be the strongest if tested to failure. thats this specific comparision
    if we were stuck weight for weight - id pick the circle in an instant - but were not
    ../delete/ban
    tech moderator
    Trailing arms being fixed at the chassis fwd of the diff/swingarm/axel tube?
    Bending in compression in that location, what did it hit? In 5 years of slamming a rangie off road never bent a trailing arm and they're round, about an inch and about 6mm wall steel. Not overly heavly though comsidering the length. backed up by a massive a arm setup on top of the diff but no other lateral location.
    Friends
    Penrith BC
    'bending in compression' ???
    ../delete/ban
    tech moderator
    Penrith BC
    bending:
    ....V............................................. .........V.....
    compression:
    ../delete/ban
    tech moderator
    Bills words in first line
    I've sen compressive deformation but only head on into a wall.
    Friends
  1. Strut tube replacement
    By jimmy19650 in forum Tech and Conversions
    Last Post: 20-11-2006, 11:09 PM
  2. air tube size
    By mrxplode in forum Tech and Conversions
    Last Post: 12-07-2006, 04:39 PM
