Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: electric ignition
    Default electric ignition
    i am looking for an electic ignition for my 18rc now i heard that it will work if i get the parts of a 22r now could anyone tell everything i need to make this work dizzy coil etc
    o and what cars ( year model ) have a 22r in them
    cheers luke
    Junior Member 1st year Apprentice Mr_Toyota's Avatar
    tasmania
    Default Re: electic ignition
    80's corona's and hiluxs i guess have the 22r, and 22re
    Im also on the hunt for a Electronic ignition for my hilux's 18r,
    do a search on the old forum i think...sure i found some stuff, ill go see if i can find it again!
    1980 RN31 Hilux, Stock 18RC with extractors!
    as Mr Toyota said, 80s Ronas, Hiluxes have them... although the hiluxes frequently seem to have the carbied version (?).
    the RA65 celica (1982ish-1985) also has the 22r-e
    tasmania
    oh yeah the celica aswell,
    22r is carby version im pretty sure, and 22re the EFI one...
    so what parts do i need other than dizzy coil
    tasmania
    http://forums.toymods.org.au/index.p...t=0#msg_125228
    here is a small amount of info, on how to put 22re internalls into a 18r dizzy, and us the 21r igniter and coil..
    cheers im gonna goto the wreckers tomorow and c wat i can find
    wood this be jus as good as instaling electric ingniton
    http://cgi.ebay.com.au/TOYOTA-CELICA...QQcmdZViewItem
    tasmania
    Dont know, but im sure its better to be "out" with the points and "in" with electronic stuff...
    Electronic ignition would be smoother, and more efficent id presume.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Twin point dizzy = points = hassle. It's fun (not) getting the dwell angle right with single points. With twins things would become even more complicated.
    The advantage of electronic ignition is that it's basically fit, time and forget. No points to wear out.
    Besides, I'm sure a DIY 22R electronic innards into an 18R dizzy is going to be a lot cheaper than that. Last time I bought an electronic dizzy and coil from Pick-A-Part it cost me $37.00. Although you will still have the standard advance curve.
    tasmania
    So the advance curve would be suited to the 22RE??,
    Can it be adjusted at a dizzy shop to recurve to suit the 18r?..any benifit doing this if its possible?
    Quote Originally Posted by Mr_Toyota
    If you use the 22R electronic bits only in the 18R dizzy, your advance weights etc are unchanged. So no issue.
    Tasmania
    You can also use the internals and coil-igniter from a 21R which are in the RA 60 Celicas also.I'm about to do this conversion also to an 18RG.As to the mallory dizzy they are hard to get bits for plus it still uses points.
    Cheers Brett.
    tasmania
    RA60 wikid, seen one at the local wreckers the other day..
    Will get some pics an stuff up when i get around to do it..
    whats the igniter look like?...is it a small box thingy next to the coil (which i need aswell right?)...
    from memory its a black box, or possibly silver, sits ontop of the coil, mounted to the same bracket. Just grab them both, saves the hassle of pulling it apart.
    PS. Hosking mate, you want "Electronic".... all ignition systems are electric lol
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. 1jz ignition
    Last Post: 04-07-2010, 08:25 PM
  3. Ignition Switch
    By rj_darlow in forum Tech and Conversions
    Last Post: 20-10-2006, 11:48 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
  5. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 12:29 AM
