only 1 thing happens per day
and another :
you will swear and throw tools..
or is that just me??
Just dont ever do things for temp, cause you will forget it and then not do it untill it falls off.
../delete/ban
tech moderator
on wiring, as i see it there are two options, based on my experience.
1. buy a half cut or a loom and ECU that has not had anything removed from it at all
2. buy an engine and an aftermarket ECU
chasing bits is no fun at all.
dont ask how much it will cost, factor in a grand on top of the cost of the engine.
buy shitloads of:
gladbags to put parts in
new permanent markers to write on things
zipties for teh win
electrical tape
wire
oh yeah, when woking on heater plumbing, use inline 6 commodore heater hoses, these are known at parts places as "the really f*cking long ones"
Originally Posted by ed_jza80
Aint that the truth !!
if pulling an engine apart:
youll need:
x5 large tacklebox trays (clear lid type)
50 pack large zip lock sandwich bags
x1 roll/box 4"x1" adhesive envelope labels
x1 fine point permanant marker (or CD marking texta)
organise and label every MF'ing damn thing you touch
../delete/ban
tech moderator
egg cartons are also good for holding individual sets like matching valve-springs & collets - a lid is highly desirable as you invariably tip the box over while searching for the mythical spare 12mm socket.
also, you will loose at least one tool in the pile of spares/left-overs you eventually dump after the conversion is done - so far i have gifted to the metal recycling gods:
-12inch long 1/4 inch drive extension rod
-a brand new, sharp, metal-cutting chisel
-1/2inch ring + open-ended spanner
also 2, do not wear a pro-drugs t-shirt while buying the 50+ zip-lock sandwich bags - the store detective will think you're a drug dealer and set the local constabulary onto you.
Originally Posted by thechuckster
ha! good point - i forgot!
Buy 2 extra 12mm open/ring spanners from supercheap
(ask justin how many 12mm spanners i have in the toolbox)
../delete/ban
tech moderator
This should probably be made a sticky in the Conversions section. It's good info for everyone considering an engine swap.
i forgot to mention probably the most usefull tool i used for my conversion:
digital camera.
i took photos of everything before, during and after the conversion.
i took photos of the engine bay from all angles and looked at the photos weeks later when i forgot where something goes or if something was there.
photos, photos, photos!
MX83 2JZ-GTE!!
#YOLO.
To me the most important this is:
DO NOT DO AN ENGINE CONVERSION ON YOUR DAILY DRIVER.
You WILL rush things, and you will regret this later.
Buy a bunky to drive for a couple of weeks so that you can do the conversion without a deadline.
Indeed.
Working on my rolla went something like this -
"well, the bigport 4AGE is out now!
*locks shed, lights up smoke and has a beer* "
Dunno why I didn't keep going. Maybe it was a rule that I subconsciously knew about. heh
edit: also, can not agree more with cruzsida's comment about not doing it on a daily driver.
I did, and in hindsight there is a lot of other stuff I would've liked to do but I rushed through it. Not saying I left out the crucial things, just I would've liked to do more stuff while the engine was out, etc
As you pull anything apart take a photo with the digital camera.
Even the simple things are fogotten after a few weeks of wielding the spanners and you forget whcih way around some parts are facing.
Graham D
Lexus RX350 (no mods yet !!!)
Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
Lexus IS200 (wife's car and no mods allowed !!!)
Suzuki GSX750-F
don't buy a motor that has a chopped loom and no Dizzy, your conversion wont get far.
and for SA memebrs, it's woth the $1 it costs to get into U-Pull-It, there are some decient engines in there, complete. Just allow a whole day to pull it out and get all the wireing.
Jordan
you mean they have a cover charge?? hehe... coolOriginally Posted by jfallen
'77 RA28LT #2 ← 2.2L 18RG...
If it all turns to shit, close the door and walk away.
You think better the next time you attempt to tackle it, next day, next month, next year.
High pressure wash everything but electrics, sooo much nicer to work on things when your hands don't go black. If you can drive it to the local car wash, it'll be the best 5 bucks you'll spend on your conversion.
And unless you like getting bent over and getting reamed for odds and ends, buy a running halfcut, so much goodness in a halfcut
And have fun, because thats why we all do it, or is it a disease
Dan
