I've not done this but.... ;ooking at this pdf:
http://members.optushome.com.au/mkha...ecu_pinout.pdf
The pin you want is number 5.
I'd presume you ground that wire.
how do i bridge the neutral start switch to be able to run a auto ecu on manual box on a 1ggte
this is wot i got told and i just want to confirm it
on your ECU, you'll see a black and white wire, and a black wire, the black and white (according to those diagrams) is labelled NS/W, and is your neutral start switch, the black, is your starter.
to get it running, i think you have to splice the B/W wire into the Black wire,
thanx
thanx lojik will try it out mate
sounds right to me.
Ground or 12+ (I haven't looked at the wiring diagram).
no worries, Let us know how you go. and don't forget to throw around some +rep
thanx boys will let u know how it goes i just have to put in the g/box in lets hoap i finish by 2morrow
i just did this on my 4ag without a wiring diagram, the way i did it was using a multimeter i checked the plugs attached to the auto box to see which combination of pins only allowed a circuit to pass through when the selector was in park and neutral... worked a treat, mind u i did it this way cos i had no wiring diagram...
hope thats of sum help!
Dave
Originally Posted by DaveW
yeh mate i did the same 2day and finished my conversion soooo happppy man
thanx 2 all the ppl that helped me out
any time mate! +rep for gettin in ther and doing the work urself!!
Dave
