From what i can see from that pic you've got the pcv hose connected correctly. If you've got fuel coming out of where you've highlighted you'd need to be getting plenty into the sump via some poor compression ring sealing, pressurising your crankcase and forcing it out the breather.
Compression test results? Otherwise, not sure how you've managed it. To be forcing a noticable amount of fuel out of the pcv hose it'd be running real rough. Factory ecu etc?
