right about the turbelence, semi right about the compression thing....
...compression is not dependent on 'dome' type pistons. you can easily have a flat top piston running a high compression ratio. 'race' engines havent used dome tops for ages (well maybe some pushrod hemis still run them). either way, higher compression gives you higher peak cyl pressures, which generates more torque... you just need a fuel good enough to resist pre-ignition when you start pushing the numbers really high
the key to a good burn is a good mix, good mix comes from turbulence - the turbulence primarily comes from 2 areas, swirl and squish. swirl is a matter of port design, sqush is from you piston/combustion chamber interface. the flat top piston design with large squish area obviously generates the best turbulence in this regard
article on squish/comustion/detonation:
http://www.v-eight.com/tech_forum/viewtopic.php?t=39
articles on intake swirl:
http://www.theoldone.com/articles/Ci...rl_Power_1.jpg
http://www.theoldone.com/articles/Ci...rl_Power_2.jpg
http://www.theoldone.com/articles/Ci...rl_Power_3.jpg
http://www.theoldone.com/articles/Ci...rl_Power_4.jpg
http://www.theoldone.com/articles/Ci...rl_Power_5.jpg
http://www.theoldone.com/articles/Ho...oft_Head_1.jpg
http://www.theoldone.com/articles/Ho...oft_Head_2.jpg
http://www.theoldone.com/articles/Ho...oft_Head_3.jpg
if i can do it with a chev on pulp you can do it with a 4a no prob! sorry if that was a hint and didnt go into detail
