Results 1 to 13 of 13
Thread: RPM Tacho Wire
    Default RPM Tacho Wire
    If i lengthen the wire which goes to the rpm tacho(ie rpm signal wire) would this change the display on the tacho to read higher/lower than the real rpm?
    I would like to know this because i have wired a shift light in and now the signal wire which was going to the tacho is now to the shift light(in series) back to the tacho.
    Thanx,
    Adam
    Default Re: RPM Tacho Wire
    Lengthening the wire will be fine.
    I probably wouldn't wire it in series though; just branch off the signal wire to the shift light.
    it said on the gizmo instructions to wire in series. probably because its a recall one(sorry i forgot to add that part)
    Should be fine, it will lag it somewhat, but considering that the electrons travel at the speed of light you wont notice it at all.
    yer if u cut it in half it will be for a 4 cyl hehehe
    if u double the length its for an 8
    just kidding
    ive never heard of a shift light to work in series
    maybe if it has 2 wires it needs light a tacho to drive it
    what brand is it
    Tis a Gizmo one sideshow
    mever heard of them
    only new "apparently" .
    hey sideshow how much do you charge(if u do it) to check my wiring to my AC if its needs fixing charge how much for that. i know it would be hard to say how much considering you dont know whats wrong with it.
    what car and engine
    i cant do anyhting till about 10th feb
    as im in perth working from 20th till 5th feb i think
    it is an AE82 100kw motor. u had previously wired it for me when i did the conversion(and we bodgey the wiring)
    anywho anytime is fine im handleing the heat......just i think winter will be worse.
    pm me say at start of feb and we will organise something
    no worries
  1. Guide - How to wire up thermofans
    Last Post: 31-01-2012, 10:22 AM
  2. URGENT!RA60 fusable crossover wire magiver quick fix?
    By andyroo in forum Tech and Conversions
    Last Post: 03-01-2006, 09:11 PM
  3. AE82 100kw motor Shift Light Install
    Last Post: 29-12-2005, 11:22 PM
  4. Starter Trigger wire Current Draw?
    Last Post: 07-11-2005, 08:23 AM
