Results 1 to 8 of 8
Thread: wiring ?
    western australia
    Default wiring ?
    ive searched everywhere i need to know where the acc wire is on an ae92 corolla seca. there are about 5 diff wires being brown/blue black/yelow black/white and brown and another one i cant remember. im tryin 2 wire my stereo up and the old wires in there dont seem to work for sum reason and ive got a really good earth and a good battery power.
    Default Re: wiring ?
    Quote Originally Posted by SKYHIONPSI
    eeeeasy.. just take your multimeter, hook it up to different wires and se which one gets voltage when you turn the key to acc
    and if that doesnt work, look for one in ur fuse box. but make sure ur wires dont touch the earth as they will melt in ur hand... from experience
    JZA023
    Western Aus
    if you dont have a multimeter, the other option, ignoring how dodgy it is, is to turn the key off, see which wire sparks when it touches earth, this is constant 12v, seperate that wire out, and with the remaining wires, switch the car to the ACC position and see which one sparks when it touches earth, this will be your ACC.
    Eldar.O.
    u ccan buy multimeters for 15 bucks at supercheap
    u could also get a test light for round 5$ or make one up wif a small light globe and two peices of wire
    lot less dodgy then Eldar.O.'s, though im sure that it will work, how well it will work, im not going to coment on ahahhah
    JZA023
    i assume your hooking up a stereo ?
    http://www.installdr.com/InstallDocs...a/Corolla.html
    look here it will have the pinouts for your vechicle so you can work out which ones are the wires you need.
    Western Aus
    Quote Originally Posted by Smokey228
    i didnt say solder the connection in, just tap the wire and see if it sparks
    Eldar.O.
  1. Replies: 271
    Last Post: 13-11-2019, 01:49 PM
  2. 7MGE and MS55 wiring diagrams
    By fatboy13 in forum Tech and Conversions
    Last Post: 29-12-2005, 02:37 PM
  3. AE111 Wiring Diagram
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 28-12-2005, 09:57 PM
  4. gearbox wiring
    Last Post: 20-12-2005, 11:34 AM
