Results 16 to 24 of 24
Thread: 20 Valve Compression readings.
    nil
    Default Re: 20 Valve Compression readings.
    150psi on a 20v of any kind is low
    its time for an overhaul
    SWAMI Garage
    vic
    Does anyone have a manual for the silvertop?
    I'd like to know what the normal cranking pressure should be becasuse I bought a silvertop 20 valve from toyospares the other day to replace 16 valve in my ae82. The compression test showed about 168psi across all 4 cylinders. I have a feeling that this is a bit low. Does anyone know what the cranking pressure should be for a silvertop? Trekka273 says the blacktop should read about 193psi and I guess the silvertop should be similar but I'd like to know what a factory manual says.
    Thanks Dave.
    I have never seen nor heard of a silvertop manual been in existence.
    When I previously had a silvertop I looked high and low for a manual and couldn't find one, and I contacted Japan, South Africa, etc. All advised that they did not know of one. I used the blacktop manual instead... I cannot imagine that there would be too much difference in the compression readings of each engine.
    wouldnt the AE101 Levins use a manual for the 20valve as they had the engine ?
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    vic
    Hmm.. if that's the case and the pressure should be nearer to 190 psi, then maybe I shouldn't have bought this 20 valve. Crap.
    Bah, I wouldn't be too worried about the compression results of each cylinder, unless it's a quality comp guage done by someone well versed in comp tests. As long as they are even between each cylinder & the motor runs ok you should be fine.
    well, it was tested again today, and last time the throttle was closed, this time it was 168 across all four. so much better result.
    vic
    Dont you people listen , import motors sit around for a long time its very normal to have comp readings that vary or are low , dont right a motor off just because of a few low comps.
    Dave
    haha im not writing anything of
    more like im buying it of
    anyways im happy with those results, and not to worried, was only worried if one of the Cyls had a lower number compared to the others.
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 11:30 AM
  2. 1ggte COMPRESSION TEST....readings.....SORTED!, cheers
    Last Post: 23-08-2006, 10:12 AM
