Page 2 of 10 FirstFirst 1234 ... LastLast
Results 16 to 30 of 139
Thread: Turbo Preference for 4age
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Default Re: Turbo Preference for 4age
    I know a chick who has a T3 off a RB20 or 25 (Cant remember) on her 4AGE, and her car doesnt spool till at LEAST 3800-4000rpm, and spools a constant 18psi until 7500-8000rpm.
    But thats crazy..
    On a 1.6L 4cyl, a T25 or a T28 would be good suited unless your insane. if your insane, try a GT35/40
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
    sa
    I only ask because I'm considering twincharging
    ......................... Carport Converter
    Also wat would be a good price for a t25g 2nd hand?
    Michael
    86 slut Grease Monkey
    glenmore park 2745
    great thread
    i would like to know what turbo would be best for a 7agte
    i want something that spools very early and dosent run out of puff
    i was thinking t25 as i am not a dyno queen and really only want 220bhp at the flywheel but i have heard it will run out of puff real early
    any suggestions
    cost not really a factor
    Cheers.... 7agte ay? something different!
    Money will be sort of an issue but if anyone has any prices it would be much appreciated.
    Michael
    sa
    Mate of mine has a gt30 on a 20v/gze block.
    155kw @ 16psi. That sudden increase in torque - that's at 5000rpm.
    I guess the options are somewhere between the gt25 and the gt30.
    I'd love to see his turbo paired with a supercharger - just to see what'd happen.
    Also would it be recommended getting an oil cooler for the setup? Or wouldn't it be a problem for such a small amount of boost?
    Michael
    Quote Originally Posted by adamaw11
    Any idea of how much that would have dropped the compression by?
    thats probably a good simple solution in many cases.
    i think i worked it out once useing the equation in the ACL gasket book, but i cannot remember now what i came too. my HG is 2.6mm thick by memory.
    Junior Member Carport Converter 4agte's Avatar
    Quote Originally Posted by Soarer_D00D
    But thats crazy..
    4000-8000 is quite a usable powerband but a gt 35/40 would be stupid unless your gonna spin the motor to 10k +
    I know of a good condition T25 going for around the $400 mark.
    Quote Originally Posted by myne
    F**k me. Does that look awkward to drive or what. Would be next to useless on the street.
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    more like would be next to FUN on the street, wheelspin anyone?
    MEGZ- yeah mate, still got the sprinter. it's out the front of my workshop with zero interior (were modifying/covering the dash etc) zero suspension (coilover's are on the way). i have the 4age ready for it, and a 4agte building in progress. it's bright blue like simons car, black bonnet. i'll get some photo's when she is all done, and i might even do a write up on the coilover conversion.
    with the turbo, your best bet is a T or GT25, maybe even a wrx turbo (which can be found for cheap) i'd run an oil cooler (you can get them from the wreckers (cheap) or new for like 400)
    or new from just jap for a 19 row for $99 altho you will need a thermostat and sandwich plate but if its for a 4age you should allready have the sandwich plate
    $99 dollars is crazy cheap. might have to get one. you may have to include braided hoses though (or rubber) and fittings
    you will have to unless you buy the 1jz or 2jz kits but i dont know if the sandwich plates would fit a 4age block
    edit: the fittings arent all that $$$ even for braided with anodised fittings it would probably cost $300 or so but obviously rubber hose and non anodised fittings would be alot cheaper
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 12:06 PM
  2. 2jz-gte Turbo Oil Feeds
    By dori dori in forum Tech and Conversions
    Last Post: 05-01-2006, 11:26 AM
  3. 5mge turbo
    By pete05 in forum Tech and Conversions
    Last Post: 18-12-2005, 08:23 PM
