Yeah, that would cause really REALLY big problems!
You need to rotate the exhaust housing round so the core is the other way around, with the feed at the top & drain at the bottom. There should be 6 or so bolts around the turbine housing you can loosen & then the whole thing will rotate. Do the same with the compressor housing to line up the wastegate actuator (if it's internally gated).
