Results 16 to 17 of 17
Thread: overheating 3s-Ge
    Rosewood
    Default Re: overheating 3s-Ge
    do the timing belt, and front oil seal while your at it. Because it isn't the easiest job in the world, and you'll thank yourself later.
    Sounds like the water pump is fsked and the water is pissing out of the weep hole (hence coming out from behind the timing belt cover).
    If you don't have a crane just put a jack under the sump with a block of wood to spread the load.
    If the waterpump looked pretty corroded the rear casing is probably pretty badly stuffed too.. if you buy a new genuine pump (i'd recommend forking out the little bit extra for one, they come with all gaskets etc) the rear casing is a part of it and you only need to undo the 3 bolts on the lower left hand side of the pump to get it off, then the two nuts that hold the water bypass pipe into the rear housing.
    Be careful if/when you remove the rear housing from the bypass pipe, if it's old and brittle it may break off in there which will be bad news (happened to me).
    Good luck
    I am the sun
  1. 4a-c Ae82 Overheating Problem!!!
    By nos4ag in forum Tech and Conversions
    Last Post: 07-11-2008, 08:27 PM
  2. 3S turbos & dump pipes
    Last Post: 03-07-2006, 09:06 PM
  3. Cooling Systems - Overheating Problems.
  4. 2S -> 3S Conversion
    By 81rolla in forum Tech and Conversions
    Last Post: 22-02-2006, 01:08 PM
  5. 3S-GTE overheating
    Last Post: 23-12-2005, 03:41 PM
