Results 1 to 15 of 26
Thread: Quads for 3SGE
    Default Quads for 3SGE
    Hey guys,
    I am looking at fitting quads to my 3SGE and was looking int 20v ones, silver or black top ones I am not sure. Will these be big enough to supply it with air?
    (\__/)
    he is gaining support
    tasmania
    Default Re: Quads for 3SGE
    they should be, i think they're 45 or 48mm
    a custom maifold will be necessary, which will cost you, depending on what it's made from.$$$$
    beer me!
    um, they are a little smaller.
    search for info on this from CelicaRA45
    TRD sell the manifold you are after. It is a beautiful piece of work - milled from a single lump of aluminium.
    I think Bill said the silvertops are 43mm and blacktops are 45mm. Not wanting to say too much but they'll be fine for an otherwise stock engine.
    Glenn can chat about this a bit more.
    tasmania
    TRD=$$$$$$$$$$$$$$$$$$
    although i guess they would have put a lot of testing into it's development.
    beer me!
    would http://www.efihardware.com/ have manifold/hardware to suit?
    Junior Member Backyard Mechanic gixer's Avatar
    Some time ago I flow benched some AE101 quads, I did put the findings on toymods, each throttle flowed 256cfm of air, for combined total of 1024cfm, I think that should be enough.
    Toyota traitor Automotive Encyclopaedia GBC_069's Avatar
    talk to trd3sg on here also - he is doing this conversion onto his gen III 3s-ge as well, running a microtech to control everything, i believe he also has a shot of NOS involved in his n/a monster.
    NOW - 2002 WRX STI - WRC Blue 180awkw @ dyno day 20
    WAS - 1991 GT4 GRP A no. 68 153awkw, 13psi @ dyno day 18
    WAS - RED ST162 JDM 86kw @ dyno day 12
    Quote Originally Posted by joecoolmk2
    You'd think so, but by the time you faff around making one, it actually works out cost effective.
    Quote Originally Posted by gixer
    But only one cylinder sucks at a time, so the overall flow isn't important as such.
    I think trd3sg was adapting a set of quads off a motorbike for his Gen3?
    Meridian Motorsport make bolt-on quads for the Gen 3 3SGE,
    http://www.mmsport.com.au/3SGE.php
    Bit pricey for my old ST162 me thinks. I thought about making up a set myself (I have access to machines, CNC etc.) but by the time I paid for materials, components and time on the machines (including test pieces) I reckon i'd only save a couple hundred dollars, THEN i'd have to go through the process of testing and refining it... it just wouldn't be worth doing all the hard work when it's all been done for you.
    Can someone explain to me what N/A has over turbo/supercahrged?
    C.j
    Instant crisp throttle response.
    Quote Originally Posted by gianttomato
    Plus the fact that you know it's 'pure'. Someone once said that a car with forced induction is like a chick with silicon implants, sure it's impressive, but you know it's not real..
    Quote Originally Posted by Ben Wilson
    You see, I just don't buy that argument.
    Fake or real, they both taste the same.
  1. Microtech + quads wont idle?
    By WHITCHY in forum Tech and Conversions
    Last Post: 01-03-2006, 12:05 PM
  2. back on dyno with 50mm quads
    By Celica RA45 in forum Tech and Conversions
    Last Post: 30-01-2006, 07:12 AM
  3. 20 valve quads the new 1s
    Last Post: 29-12-2005, 08:24 PM
  4. Thoughts on NA Quads Plenum Setups
    Last Post: 07-11-2005, 08:04 AM
