Yeah they do, so don't worry unless it's been changed prior. It should have a red sticker on the back that says 'LSD oil only' or something similar. Best way to tell is to hold the diff drive shaft flange so it won't turn then rotate one side axle and see what the other side does. If the axle on the other side turns in the same direction(from the same perspective) it's a LSD. If it's turns in the opposite direction then it is a normal open diff. If it's hard to turn by hand than that a good sign the clutch plates inside are not totally stuffed. A normal open diff is much easier to turn by hand.Originally Posted by PureHell
