Results 16 to 30 of 30
Thread: 1GGTE need better clutch!
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default Re: 1GGTE need better clutch!
    if i can find something for under 300 im happy
    that PBR one sounds like a place to start
    a fool remains undescovered untill he speaks!
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    How does teh is200 box last with a tuned 1G? I heard they were a little fragile?
    Also what flywheel are you using? The is200 one has a built in slip system to dampen the clutch...
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    Aug 2006
    Selangor D.E.
    True. The original flywheel from the vvti 1gfe has some sort of a damper in it. ( have a pic posted on the old toymods forum )
    My clutch was slipping everytime I floor the stock gen3 1ggte. Changed to a normal flywheel and a hilux clutch but using the original pressure plate, felt a bit better but must lengthen the rod on the slave pump coz the flywheel is much thinner. Still slip a bit.
    So I took out the pins on the flywheel, had my friend skimmed a bit the outer part ( not the clutch contact part ) for the pressure plate to sit a bit deeper, now it is working fine.
    i got one of the daiken heavy duty organic, aparently it used the same pressure plate as the ceramic one mentioned above, aprox 40% more clamping so should be perfect.
    best part only cost $185 trade for the whole kit
    not installed yet will keep you informed as to how it goes
    Junior Member Automotive Encyclopaedia Big rob's Avatar
    I have a hilux diesel pressure plate and clutch. It hasnt slipped yet and for some reason the pedal is lighter than my mums corolla, i think the pedal travel is longer on my soarer though. I just went to a clutch guy to get something that fit the only thing is I think I have a 7MGE flywheel on there. It cost $250, just go to a clutch shop and tell them what you want and look at your options.
    Quote Originally Posted by 1jzracing
    Bargain!
    Big Rob - The HiLux diesel one, is that a "4Y engine code" clutch?
    mate i am not sure. I saw this guy selling a GA70 clutch on ebay through his shop and just took my flywheel down there and it turned out it didnt match. So we just fitted stuff till it did turns out a hilux diesel fitted and since it was diesel i tohught it would carry a bit of extra load. Whats a 4y 2.4lt, I remember it being off something similar to that capacity.
    I am not sure of what a 4Y even is. I supplied a clutch for an import that also suited the 4Y. That is why I was asking.
    as a (not so) random question, and sort of on topic... how expensive are the friction surfaces on twin-plate clutches to replace?
    I'm looking at buying a second hand one... but I want to know whether it's worth it
    Just looked at some hilux info on the net and the only engine I can find in a 2.4lt diesel is the 2L series but it makes no torque and power. Max 170nm at 2200 rpm, I wonder if this thing is it but i doubt it. Maybe it was a 2.8, that seems to be more common.
    Rama,
    Do you have a part no. for that kit. I've just pulled the old 22R out of the Hilux and I think I might replace the clutch while I'm at it.
    Thanks,
    Peter
    Junior Member Backyard Mechanic ndgcpr's Avatar
    I rode my HD clutch once (although quite exsessively) and it slipped on the high way. the stock 1G NA one melted fast and i now have a 5 puck sprung center. it takes a little getting used to but half the time you wouldn't notice i had one, they arn't as bad as you may think.
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    I've been running a Hilux clutch in my Drift GZ all year, no problems at all & thats been at 280-320odd bhp all season. I've done about 8k miles driving to & from events too.
    This thing has had some serious 4th gear clutch kicking abuse too!
    Its still in one piece!! & looking good lol
    Quote Originally Posted by infotechplus
    Rama,
    Thanks,
    Peter
    Part number .... TYK 6311-HD
    this is for the pre '88 smaller gen 1or2
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Don't know if this applies anymore, but when I got my exedy / daikin clutch I'm pretty sure it said if you dont get the flywheel machined then the warranty is void on the clutch. Not sure if that's the case anymore but just thought I'd mention it just in case.
  1. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 10:12 AM
  2. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
