Results 1 to 15 of 22
Thread: Needing Someone With 7mge Knowledge
    Junior Member Backyard Mechanic sunkloto69@hotmail.com's Avatar
    Default Needing Someone With 7mge Knowledge
    my flywheel is touching my sump.... im scared...if my motors stuffed i WILL cry !!!!!
    what does it mean and how bad is it....it rubs evenly against it the whole time i turn it over so i dont think its a warped flywheel.....the motor supposedly ran fine
    Default Re: Needing Someone With 7mge Knowledge
    picsorban!!!
    coz i dun believe a flwheel can be that close to the sump...
    i havent got a camera but the back of the sump... the lip of it is rubbing against the front of the fly wheel and i looked at that blown 7m i have for comparison and that 1 is a little further away, but every half turn it rubs...so its warped where as the good 1 in my supra rubs the whole time :S sum1 helpppp lol..... i cant handle ne more bad news on this car
    Junior Member Domestic Engineer urantia's Avatar
    This is a wild shot, but with the 3sge motor there is a plate that you bolt up to the gearbox which blocks up a big window where the engine and gearbox mate. That plate can on occasions get out of shape and touch the flywheel. I can't remember if the 7m had this plate as well. (i reckon it does)
    Either way the flywheel isn't going to touch the sump unless the sump has been severaly distorted, or the flywheel has become warped to not fastened properly. Neither of which i doubt is the case.
    98 3rz-fe Hilux 4x4
    Unhappy Re: Needing Someone With 7mge Knowledge
    thanks for the help, unfortunately that little plate isnt on atmimagine the sump up under the car....and around the outside u have the flat edge that all the bolts go thru, the edge of that is rubbing up against the flywheel...ill get picks up tomoro.... its not a warp problem either cause it does it the whole time it turns, thanks for your help +rep, Dave
    how odd! yes pics would be great. Crank walk maybe? Hmm will have a think about that one.
    3:30am i better go to bed
    98 3rz-fe Hilux 4x4
    S.A
    need pics to help ya mate. Can you move the crank backwards and forwards, mabe the thrust washesr are gone. is the balancer at the front touching the timing cover? just made this post on my phone at work! Ahhhh technology.
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by 30psi 4agte
    DAVE HAS I am unsure of his login but he owns 2 mK2 and a TLC all with the big engine.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    You have this question in "General Car Talk" so I have just copied my comment to this thread.
    Just a small note. The flywheel bolts to the end of the crankshaft and should not matter what gearbox is being fixed to it. Changing gearboxes should have no bearing on the flywheel position. If this is now the case you might have bolted the flywheel on around the wrong way moving it closer to the engine.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    Question Re: Needing Someone With 7mge Knowledge
    Quote Originally Posted by hi-ace
    yeah a mechanic suggested that today... the story is the car was running and that the gearbox was stolen ( why ne1 would go to the trouble to steal a 7m auto is beyond me cause it was slipping like shit newayz ) . so theres no reason the ring gear shuld be on backwards...its looking more like someone has fiddled with it and left the spacer off unless we have smartass thieves who steal ur box, taking ur ringgear off then remove the spacer and bolt it back together and giggle at the thought of u trying to work it out. i took a pic on my phone ...it is Major shit quality but better than nothing
    Is it just me, or is that a picture of nothing!
    sunkloto I thought we were seeing pics of the flywheel business, not you out raving on the weekend
    bottom half is the sump top half is the ring gear ...lol...anyway just ripped the ringgear of and its buckled problem solved..how much am i looking at to get it machined or am i better of replacing it from a wreckers...thanks for all your help
    maybe just replace whole flywheel.. perhaps the engine was dropped onto the flywheel at some stage, knocking the ring gear off?
    the story of someone stealing the gearbox sounds very very very dodgy.
    the motor hasnt left the car ...i dunno which it is cause im stupid lol...im talking bout the big thin plate with round holes, teeth and it bolts to the back of the motor then the torque converter....thats the buckled thing
  1. 5MGE and 7MGE Oil Pumps
    By Art Racing in forum Tech and Conversions
    Last Post: 07-10-2006, 06:43 AM
  2. Project 7mge to 7mgte %90 done -%10 need help
    By Mk3_supra in forum Tech and Conversions
    Last Post: 12-08-2006, 10:38 PM
  3. 7mge Headers
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 09-05-2006, 06:20 PM
