http://www.club4ag.com/technical_main.htm
Don't know if this is what your after but there is some in depth info there
 20V fault codes
 20V fault codes
				Does anybody know how to get a fault code out of a 20V ECU? which pins do I short and does someone have a list of what codes are what?
thanks in advance
				 Re: 20V fault codes
 Re: 20V fault codes
Ben.
 Re: 20V fault codes
 Re: 20V fault codes
				Looks to be the goods
oops, wrong link...
http://www.club4ag.com/faq%20and%20t...ic%20Codes.htm
Hydra
JZA61 Celica XX
 Re: 20V fault codes
 Re: 20V fault codes
				thanks guy, I initually was at club4ag before posting this but I overlooked the article.
I got all excited when I saw the 20V.org website then I realised it was for a damn Audi
 Re: 20V fault codes
 Re: 20V fault codes
				Yeh that damn audi site - got me too.
The 20V I wired up came with the AFM wire cut... I am guessing an interceptor was placed on there or something because it looked like it was done fairly profesionally then hacked apart by the wrecker.
Hydra
JZA61 Celica XX
 Re: 20V fault codes
 Re: 20V fault codes
				I think the problem is the fact that I missing an air-temp sensor. I know its a bit off topic but where is one located on a 20V and whats it looks like? I hoping to fit a 16V one
 Re: 20V fault codes
 Re: 20V fault codes
				I can look when I get home tonight
Hydra
JZA61 Celica XX
 Re: 20V fault codes
 Re: 20V fault codes
				Argh, still haven't had a chance to be home at the same time as the 20v, but I will as soon as possible.
EDIT: Hmmmm for some reason i recognise the code 24 though, I think that was the code that was giving us trouble. That was in relation to the AFM of course... I could be wrong though - will once again look at it tonight.
Hydra
JZA61 Celica XX
 Re: 20V fault codes
 Re: 20V fault codes
				Gah, how could I forget - the air temp sensor is a part of the AFM on a silvertop. So check the AFM is getting 12v on the right pin etc etc
Hydra
JZA61 Celica XX
 Re: 20V fault codes
 Re: 20V fault codes
				ok thanks, I didnt get to setup my car to get a signal out of it yet but I will
