Results 46 to 59 of 59
Thread: Ford 5 stud disc brakes
  1. #46
    Taking Forever To Build Grease Monkey SLO-70Y's Avatar
    Default Re: Ford 5 stud disc brakes
    I rang DBA about 3 weeks ago and they told me that the 604 calliper didn’t come in slotted form who were you going to go through?
  2. #47
    Quote Originally Posted by SLO-70Y
    Get them from RDA
  3. #48
    Yep yep and cheaper too.
  4. #49
    Ok sweet thanks I'll give them a ring see what i come up with
  5. #50
    B&R brakes in castle hill is a toymods sponsor i should add, which stocks RDA. With discount for financial members.
  6. #51
    Montrose
    Use R33 turbo brakes (297mm) and the matching 4 potters, but maybe with BA rotors, depending on the strut you choose. Look into RA6x, MX73, MX83, XT130, and even bits of RA40. A bit of time spent matching hubs, bearings, struts, etc. and you should be able to have yourself a reasonably priced brake upgrade. Don't bother looking for impossible to find parts, such as MS65 hubs, because if you do find them, usually people want far too much for them. A bit of time in a bearing catalogue, and on a lathe, can save you a fortune.
  7. #52
    from memory s13 range werejust large single spot slide calipers were they not???
    Black Betty >HERE!<
    (\__/)
  8. #53
    my ke30 is 5 stud all round
    i used corona struts with crown hubs (ms65) with pug 604 rotors and hilux 4spot calipers
    all bolts up and passed engineering no worries
    KE38 - 2TG
    MS65 - 1UZ
  9. #54
    hey i dont know if this is really what you are after but have had vr commodor disks machined and have had corolla bearings put in them( sleaves were obvioulsy made to make the bearings fit) along with a caliper braket to make vr calipers fit, i am the same boat as you as i have a commodore diff in the rear and i wanted all of the stud pattern matching, and bit the way i have a sr20de+t in mine. And it was mr enforcer that did my machining.
    slippery when boosting-ke30 sr20 underway
  10. #55
    I didn't see it mentioned yet but another option is Hopper Stoppers in Vic, they have some nice stuff and they can make to any stud pattern you want. That's the way I'm going, I just have to work out something for the RT142 IRS rear to make it also ford 5 stud.
    Does take the fun/joy/pain of doing it yourself although may be more $$.
    Ex
    86 Corona RT142, King springs & Bilsteins
    Parts - See Here
  11. #56
    Thanks guys I'll look into all of those to see what comes up, i also was told that a later model crown hub i thinks its the Ms112 or something like that would fit on a RA celica strut only because the bearing on the celica is bigger so it would fit the larger hub. Is that true
  12. #57
    Aug 2006
    just in case you haven't already found a solution to you 5 stud dilemma i have a scenario that will work but will require a lot of searching for stuff in japan.
    1. First you will need AE86 or XT130 corona struts
    2. Custom camber tops to suit the KE30 (if the AE86 ones don't fit, pretty sure they don't), or you can just use the KE30 strut top on AE86 struts the spring diameter is the same
    3. Procure for yourself a set of "GX 72" (and be certain that they are GX 72 or else they wont
    work) hubs, rotors and calipers.
    These have the same stub axle as the ae86 and the same part number for the wheel
    bearing as the four stud sprinter brakes, so they will go straight on
    4. If you want a brake upgrade from there, then you can always go the 33 caliper and BA rotor
    mod like with the MX83 but you will need to make a caliper bracket and ring spacer for the
    hub.(just like when using JZX100 rear discs and 33 rear calipers on the rear of MX83)
    its not much but i hope it helps if you need to know more give me a call on 0416265877 matt
  13. #58
    wow great info there
    KE38 - 2TG
    MS65 - 1UZ
  14. #59
    Quote Originally Posted by mini_andrew View Post
    3. Procure for yourself a set of "GX 72" (and be certain that they are GX 72 or else they wont work) hubs, rotors and calipers.
    Are MX72 (ie Cressida Wagon) hubs different to GX72?
    ([][][]II--LT--II[][][])
    By The Witzl in forum FAQ
  2. Early corona 5 stud conversion and big brake's
    By SRacin in forum Tech and Conversions
    Last Post: 22-09-2010, 10:32 PM
  3. hilux diff disc brakes
    By jcmunga in forum Tech and Conversions
    Last Post: 14-05-2006, 10:00 PM
  4. Replies: 97
    Last Post: 31-01-2006, 12:43 AM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
