What size tyres have you got? I'm running 205/50 15's on 20P offset 15 x 6.5's. No real clearance issues.
you can check your offset as follows -
Pull the wheel off and lay it face up on flat ground.
Measure from ground to the hub mounting face (call this A), then flip over and do the same (call this B, make sure this is still to the same mounting face). Add A and B together and divide in half (call this C). The difference between C and A is your offset, If A is more than C the offset is positive if less its negative. You need to be pretty accurate with your measuring though.
Callum
