...continued from previous thread.
the original rear mounting locations of the subframe on the s13 body can be seen below
The chassis appears to have a crossmember running between the rear chassis rails where the subframe attaches. This crosses behind the rear torque box and in front of the spare tire well... but rearward of the diff.
The front mounts can't be seen clearly here, but actually attach to the chassis in a similar position to the lower trailing link mount on the celica.
I don't know the distance between the two rear mounts, or the two front mounts, or what distance is between the front and rear mount. Perhaps someone with access to a vehicle could measure the distances and PM me so i can include it. hint hint... IT would be great to be able to see what would actually have to be moved. Hopefully not the fuel tank.
The other dimension I would like to confim is the distance between the centres of the two strut tops and how high they sit above the centre of the hub (for lack of a better reference).
For those interested, the above pics can from a site where a guy was plonking a morris shell over a shortend 180sx. So crazy it's cool!
What's under a celica in these places:
The celica uses a four-link live rear axle which has pickup points for each of the links forward of the axle.
There are also outboards mounts for the springs which would have to be modified to fit the coilover shock. The shock mounts on the celica would no longer be required and neither would the panhard rod mounts.
