My clutch pedal and master cylinder are in and working!
This is not to be taken lightly!! As the process involved removing half the dashboard just to see where it had to go!!! After a long involved process of making sure the holes are correctly aligned, it all went together.
Some points to note.
* There was a cutout on the firewall - engine side - for the master cylinder. No holes where there however.
* There was a perforated section of insulation on the firewall - interior side - showing the general location of where the clutch pedal bracket had to go. Once again, no holes were predrilled.
* A few measurements had to be taken from reference points to allow good alignment. There are 3 bolts holes at the top of the dashboard where the pedal bracket can bolt. I have no idea why there are 3, perhaps for different designs of bracket. However in this case, I chose the middle hole, which was slightly elevated above the other two. By eye, this looked to be the correct position. Holes where marked through the bracket using a pencil. The larger hole for the master cylinder pushrod/rubber was cutout using a 32mm carbon cast metal hole saw. The other two where simply drilled out with 8mm drill bits. After a bit of "manipulation" it all went together well.
* The pedal arm is VERY difficult to get in AFTER you bolt the pedal box up. Best to attach the arm before you install the pedal box.
* The spring return can't be installed without the master cylinder being connected to the pedal arm. A bit of fiddling is required to get the clips on and off once everything’s bolted up.
* Driveshaft nut size, 30mm
* I'm using my VZV21 V6 drive shaft’s and CV's which are all from my A540E.
Some pics.
The clutch Master Cylinder bolted up to the firewall.
The clutch pedal in!
The general alignment of the three pedals.
I found it is better to install the clutch pedal before the master cylinder, as it gives you access to the master cylinder and running the hardline across the firewall. The clutch pedal in my car was off an SV21, so same basic chassis. As I said before, there were 3 different alignment holes, which I assume where for three different types of bracket. I just used the one that aligned the best with the hole I made in the firewall for the master cylinder. Two of them where off by quite a bit, so it wasn't too difficult to see which one was going to fit. Getting the holes drilled properly was the hardest part, as I didn't particularly want a wonky clutch pedal! And even with the bottom of the dash out, it was still an effort on the arms to work in the tight space that Toyota provides.
My auto gearbox is now out! Flex-plate is off as well. The top mount has been customized to suit this gearbox and is ready to go back in. The front mount will bolt up with no drama at all! The rear mount will require part of it to be cut off and rewelded in a different spot, but the actual mount holes line up perfect. This thing wasn’t hard at all to get out, very simple. It might look big, but once its balanced on a jack, all is good. Just slid it out under the car.
There is a spigot 'indent' on the crank, which I later found out at Toyota, these don’t use a bearing so all is simple in that department!
