Results 1 to 4 of 4
Thread: 7MGTE wiring
    Default 7MGTE wiring
    Hi all... just a quicky..
    does anyone know if a 7MGTE wiring loom is the same for Auto and Manual ECU's??
    I wanna wire in a HKS FCD..
    its coming out of a manual and into my car which is currently running a auto ecu.. (even tho its a manual gbox)
    would it just be a matter of matching up what wire is connected to which wire.. or am i going to hit complications?...
    unfortunatly we don't have install instructions for the HKS FCD...
    Damo
    TRD83
    Default Re: 7MGTE wiring
    Wiring wise they should be the same for what you're after.
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    First thing damo, which gen of 7MGTE is it? gen 1 or gen 2? Gen 2 i think has a yellow screw near the Throttle body somewhere.. The ECU pins are different for both gen's.
    T6 is gen 1 7M pins, T7 is gen 2 7M pins
    This is the FCD Installation Guide -
    http://www.therealaussie.com/auto/to...cs/hks-fcd.pdf
    You should be able to put two and two together with this info.
    i.e. Red Wire to power, black wire to ground, splice airflow signal wire from ECU and solder the yellow wire to the ECU harness and white wire to the other end that you just cut, then green wire to RPM signal. simple eh!
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Its a Gen2 ECU
  1. Sam's MA61 7MGTE Conversion
    Last Post: 10-11-2006, 12:08 AM
  2. Aftermarket ecu installation questions. (7mgte)
    Last Post: 28-09-2006, 12:10 AM
  3. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 07:29 PM
  4. 7MGTE Ignition signal wiring question
    By 1200det in forum Tech and Conversions
    Last Post: 07-01-2006, 12:16 PM
