Im doing the same conversion at the moment and its not worth it. Wait and find a jdm ke70 front end, looks so much better and bolts straight on. I got 148 mm as the diameter.
Des
Hey people
I need to know the size of the stock TA22 sealed headlight. Can anyone tell me the diameter of them??
I doing a quad headlight conversoin on my ke70 and want aftermarket H4 headlights
Craig
N/A 3SGE KE70 on its way
Des
Originally Posted by too_quick
Why do you say that??? Is it just a bitch to make up brackets and get the aim right???
Im using the brackets from the ta22 and its really hard to get them to aim up properly, plus you lose the parking lights as they are attached to the square head light surround.this is what ive done so far its shocking but im going to try and fix it up tomorrow.
Thats a fair effort dude.
The parkers wouldnt be that hard to get back. They only need one screw hold them in. So mabe just some little brackets coming off the ta22 headlight brackets. Or isn't there enough room for them??
diameter is 5 3/4 inch = 146.05mm. this is the front of the glass
1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
2. Don't argue with an idiot; people watching may not be able to tell the difference
There would be plenty of room if you use the ta22 grille like i did in the pic.
Im using the ke70 grille but ive cut it a bit.My car isnt going to be on the road again so im not to worried about the parkers being there. Mine are only held in by zip ties at the moment but im goin to bolt them in tomorrow maybe if i have the motivation to get out of bed before 10am.
Originally Posted by ta23-mbzq-nnr
Cheers dude and this is how they measure them when you aftermarket ones??
If you dont have one i can take one of mine to repco and get a part number for you tomorrow?
Yeah that would be good please.. I liked it better with the ke70 grill
Will get back to you tomorrow about a price and part number. If the ta22 grille was longer id use it but its to short so i used to ke70 one and cut it down a bit. The wiring im just hooking all the lights to low beam and high beam so it gona be bright.
Cheers dude your a legend
hey hey
The part number for the 50 watters is 6299951 and thats from repco.
50 watt $15 each
100 watt $30 each
Des
Cheers for doing that dude..
Also what have you done to the TA22 headlight brackets to get them to fit the ke70??
I went out today to do some more work on them and to get them to mount and line up properly i need to cut some little bits of the radiator support panel and i dont want to do that so im going to put my square lights back on and wait for a jdm twin setup to come by.
But by all means go for it. I wish you the best of luck with the conversion.
