Page 54 of 68 FirstFirst ... 444525354555664 ... LastLast
Results 796 to 810 of 1006
  1. #796
    working hard Backyard Mechanic
    Default Re: [Guide] Corona/Peugot/Hilux Conversion with Height Adjustable Coilovers [56k DIAF]
    I bought a set of bendix ultimate db1170 for a 200sx , hope they work out
    Depends on the pads you run, the DS2500s i tried would have needed to be filed.
  2. #797
    The DB1170s wont fit the staggered piston calipers.
  3. #798
    Ive got the lastest model caliper with the two big pistons "same size ones"
    So they should fit yes ?
  4. #799
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Yes, it is the "different sized" piston caliper one that takes the RX7 Pad.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
  5. #800
    appreciate it guys
  6. #801
    May 2007
    A question for the learned.
    The first page of the thread shows an image of the 2 different Hilux/Landcruiser brake callipers. The one on the left has fins whereas the one on the right doesn't.
    Which calliper is the one that takes the 200SX, R32 or R33 callipers and which is the one that takes the series 4 RX7 calliper?
    Apologies if this has been covered already in this thread.
    Thanks,
    1975 3T-GTE TA22 Celica
  7. #802
    This is what i was trying to find about before, by posting up what caliper i had... The left "two same size pistons" takes the r33/200sx/r32 gtr pads Bendix part # db1170 and the right caliper with "different size pistons takes the rx7 series 4 pad.
    Quote Originally Posted by RBP690 View Post
    Thanks,
  8. #803
    May 2007
    Quote Originally Posted by reece12 View Post
    This is what i was trying to find about before, by post up what caliper i had... The left "two same size pistons" takes the r33/200sx/r32 gtr pads Bendix part # db1170 and the right caliper with "different size pistons takes the rx7 series 4 pad.
    Thanks heaps for that.
  9. #804
    I don't know if this is worth changing, but this quote from the wonderful first post is a bit confusing.
    "However, the LN106 only came out with the one caliper, wheras the Hilux of the same era came out with both. Some wreckers will try and sell you the Hilux caliper as the Landcruiser It is not a particularly big showstopper, as both will work fine. The Landcruiser caliper takes the 200SX/R33/R32 pad, wheras the Hilux caliper will take an RX7 Series4 pad."
    It mentions the LN106 and the Hilux of the same era. Well a LN106 is a Hilux, so I'm not sure if that is meant to say Landcruiser instead of Hilux, or Landcruiser instead of LN106?
    Also it says the Landcruiser takes the nissan pads. My caliper from an FJ60 Landcruiser front is the twin sized piston type which definately takes the Mazda pads. This section may be worth cleaning up based on some of the confusion in the last few posts. Perhaps rather than reference Landcruiser/Hilux calipers it should be rewritten using the number stamped on the caliper and mention what vehicles they might be found on?
    Just a thought, awesome writeup though it has been most helpful!
  10. #805
    I was wondering if the Straion MC will bolt up to a T-18 Booster? If not does anyone know what MC i can use for the upgrade? Cheers
  11. #806
    Anglo maxum Grease Monkey
    Jun 2006
    i have heard of issues with the control arm hitting on the rotor.
    now my setup includes
    60mm cut tube, 10mm spacer for hts102
    pug rotor
    gh sigma arms
    xt130 struts
    40mm rca
    im still waiting on parts so am yet to see if it fouls, but
    are there any problems regarding 86 power steering arms,
    if so are there any problems with swapping them side to side other than
    the positive camber, which would mean very little to me as i could get it back
    with the camber tops.
    thanks
    ke70, drift/hillclimb/sprint special
    bells AND whistles.
  12. #807
    Ive read and its been confirmed that using RA22 or XT130 steering arms fixes the fouling. But makes steering a bit slower. I see you are on AE86DC like me trying to find everything out lol. Would be good to find out about using the AE86 power steering arms on oppisite sides as i have a pair sitting in the shed.
  13. #808
    Junior Member Backyard Mechanic chaRwie's Avatar
    those who are looking for upgraded pads for the corona 2 pots
    i've been following a awesome thread on jdmst about a guys hakosuka skyline
    he changed his pads recently, and they look almost IDENTICAL to the corona 2pot sumitomo brakes
    can anyone confirm this?
    linked pics
    Sold: RA28zoku - Bosozoku inspired
    Weekend: JZX100 Mark II - VIP inspired
    New Daily: GX71 Mark II - Bosozoku inspired coming soon...
  14. #809
    it wouldn't suprise me charwie, apparently hilux brakes are a boltup upgrade for 260z's and such as well. sumitomo are just a brake supplier to the manufacturers, they actually make the skyline and silvia brakes, except for most gt-r's which have brembos
  15. #810
    Yes this would be accurate - the Sumitomo caliper is likely to be similar to Z cars. I found I could buy all manner of pads off the shelf for this caliper, as it takes a pad the same shape as Datsun Z cars (common upgrade for rallying people with 1600's / 180b's etc) and also Mk 2 Escorts.
    So there are heaps of different pad options for the Sumitomo caliper
    Now - RA23-WRX
