Results 1 to 14 of 14
Thread: reservoir fluid extraction
    Default reservoir fluid extraction
    With out going to the trouble of a small electric pump, battery, wiring, switches, hoses etc. What is the best way to "vaccum" fluid from reservoirs - ie power steering, brake, clutch, even overflow bottles ??
    The only good suggestion i've heard was a large syringe ???
    What do you use ??
    Default Re: reservoir fluid extraction
    undo mounting brackets, tip into bucket that you can squeeze underneath item?
    I use a big arse syringe with a bit of vac hose on the end, that works a treat. It helps when you can get the syringes from work for free too.
    syringe is the go, previously i have used a length of hose and the vacuum effect.
    1. stick bit of hose in resevoir
    2. stick finger over top
    3. pull hose out of resevoir
    4. put hose over top of gatorade bottle
    5. take finger off top of hose (fluid falls out into bottle)
    go to step 1.
    takes a long time, i did it when i fitted new brake pads and had to get rid of the excess fluid, really should change my fluids now i think of it.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Large syringe would be the easiest...
    But, if you have access to an air compressor with an air nossle, you can:
    Step 1: Place a piece of tubing (fuel hose, vacuum line, etc...) into the fluid.
    Step 2: Place the air nossle in the reservoir, and seal with your hands (having the tubing and the air nossle being the only things that are coming through your created seal).
    Step 3: Apply the air...
    This will cause the pressure to build up and expell the liquid through the tubing!
    ([][][]II--LT--II[][][])
    Go to chemist and ask for a 50 mL Tuohy catheter tip syringe (this way nobody looks at you like you're some drug fucked piece of shit). Bit of vac hose on the end ftw.
    Good ideas, thanks.
    I have an old battery specific gravity tester (Hygrometer) that performs these tasks admirably. Comes complete with flexible end !!
    cheers Chuck.
    MS51Crown Coupe,
    Montrose
    Some ATF bottles can be sort-of alright for this purpose, but the electric pump = the winner really.
    Junior Member Backyard Mechanic M.J.H's Avatar
    Quote Originally Posted by shinybluesteel
    go to step 1.
    Or just use a long clear hose and suck until the fluid is nearly to the end of the hose.
    Doesn't take long at all.
    My sig has been pruned as it was over 5 lines long.
    use a piece of thick cloth (like a towel) as a wik. Just sit the end in there and dangle the rest into a container for brake fluid or over the side it it's water.
    But a syringe is nice.
    Hello.
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    i used a coke bottle with a hole in the lid, a piece of tube through the lid and sealed up with blue tack. then just squeeze the bottle and stick the hose in the reservior and release. its good and itll empty a master cylinder in a couple of squeezes.
    I have a Crown
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by STR8 2.8
    Syringe or mothers breast milk extractor or Yogurt pump or an old tomato suace squeeze bottle. just dnt drip it on the paint work or at least wash it if you do
    the inept Grease Monkey Thomas's Avatar
    If you're really desperate you can use a liquid soap dispenser head. Takes a fair few pumps though.
  1. here's a retarded question (re: power steering fluid)
    By Draven in forum Tech and Conversions
    Last Post: 22-08-2006, 05:53 PM
  2. Concentrated vs PreMixed Radiator Fluid
    By MarioM in forum Tech and Conversions
    Last Post: 17-08-2006, 03:29 PM
  3. accidently toped up power steering with brake fluid?
    By gerald1 in forum Tech and Conversions
    Last Post: 12-08-2006, 05:52 PM
  4. How long can Brake Fluid last?
    By Big T in forum Tech and Conversions
    Last Post: 19-03-2006, 07:56 AM
  5. power steering fluid
    By off-road in forum Tech and Conversions
    Last Post: 12-03-2006, 08:48 PM
