Results 61 to 75 of 76
Thread: sc400 Rev cut a 3750 RPM HELP URGENT
  1. #61
    Jun 2006
    Default Re: sc400 Rev cut a 3750 RPM HELP URGENT
    Do you have anymore info on this test drive mode as someone has said something similar before.
  2. #62
    Quote Originally Posted by Buttocks
    I don't know if a few of you guys have ready the whole thread. Its not breaking done at 3800rpm its a proper rev cut at 3800rpm like the computer is in a valet mode or a feeble limp home mode
    i read the whole thread.
    what do you mean "its a proper rev cut"
    there is no such thing as a rev cut it's either spark cut or fuel cut... and this acts as a rev limiter.
    check which one it is, and compare that to how it should behave.
    you said you already changed the ECU... so it must not be that. no??
    until you actually meaure things, you are just guessing that it has a rev limiter thing happening..
    you can either keep guessing in the dark.. or you can check what is physically happening.
  3. #63
    Jun 2006
    Ok dokie will do
  4. #64
    test drive mode
    never heard of it on jap cars
    maybe only wrxs
    anyway has the car ever run good
    did this just recently happen
    if so then i dont think its in test drive mode
    maybe try disconnecting battery overnight to reset things and see what happens
    i offered to look at it and will be up that way in 2 weeks but now i wont be up that way long enough
    i diagnose alot of jap crap cars too
    thing u have to remember these ar eone of the worsts cars to work on when it comes to checking alot of the ecus under the dash/kickpanel etc area
    they have alot of ecus talkin to eachother
    abs ecu
    traction/abs ecu
    engine ecu
    fuel pump ecu
    cruise ecu
    and many more
    anyway he wants to fixx this prob himself otherwise the thread would not have wasted 4 pages and 10 minutes of my life hehehehehehehehe
  5. #65
    hm.. that's what i thought.. but apparently it happens on other jap and euro cars as well.. the limit can be anything from throttle limit, to timing and fuel...
    yeh that's one of the things i dun get.. fuel pump ecu?? japanese must've gone mad at some stage and installed an ECU for everything.. even electronic dashes are one big chunk of mainboard..
    anyway good luck with it mate.. take up the offer if someone can come have a look i say.. just to be sure.. i'm all out of ideas.. sorry
  6. #66
    Junior Member Grease Monkey MacroP's Avatar
    Having a Soarer engine I can say that the fuel ECU can be bypassed and the TRC ECU can be unplugged without harm. You can use a good meter on the diag conn (FP) to measure the voltage going to the fuel pump and back to the engine ECU. A CRO would be better as it's a PWM signal. The Soarer engine has feedback from the Fuel Pump ECU to engine ECU. I guess if this signal is not correct than the engine ECU could force a cut to protect the engine maybe.
    On a lot of Toyota's I've noticed you can bypass all the fuel pump control by putting a bridging wire from B+ to FP in the connector. I did noticed on this engine though the FP wire going from the diag conn to the main loom is very small so I would not recommend putiing a bridging wire in here. I don't think is could support the current needed to power the pump. Just use it to monitor the fuel pump voltage.
    I have heard on Soarer Central that the Fuel pump ECU is a common fault though I can't remember how the engine ECU reacts to this.
    Hope this helps.
    MX83 1UZ Conversion. UZZ31 engine, UCF10 Sump, UZS131 Tranny and engine fan idler. Custom exhaust and 147rwKWs.
  7. #67
    Jun 2006
    I swapped fuel pump ecu's and bridged the 2 curcuits, i've done all the tests i can think of on the fuel pump side of things, think elsewhere. Whoever guesses the problem gets a Free Slab - Beer or Coke for the youngun's
  8. #68
    Does this happen when only driving or when free revving in both neutral and park?
    So, just to clarify - The problem existed right from pickup, straight off the boat so to speak.
  9. #69
    Jun 2006
    Yes the car has always had the problem since it was imported
    And it hits the cut in everyway, N, P and in any gear
  10. #70
    Have you checked the TPS yet?
    All Toyota ECU's have a safety for a failed TPS.
    A TPS is in IDL mode when there is no pressure on the throttle.
    While the TPS is in IDL, the motor will not rev over a certain amount.
    Its possible the TPS, and/or the wiring between the TPS and the ECU is faulty, and thus the ECU thinks the TPS is in IDL, and will not let it rev.
    I'm not sure if this will affect the drivability of the car. I'd hazard a guess it would, and thus could possibly not be your problem. But its worth a check anyhow.
    Test the voltages of the TPS pins at the ECU with it all plugged in, and see if the circuit between IDL and E2 goes open circuit when you put your foot on the throttle.
    I doubt any diagnostics would pick this up, because most Toyota diagnostics require the TPS to be in IDL to work (such as the self diagnostics)
  11. #71
    Quote Originally Posted by Vios-GT_07
    this might also sound pretty stupid but have you checked TPS and throttle cable??
    i did suggest you this first.. *meh* if that's the solution.. me and cruzida.. we'll share this slab of beer.. i'm still waiting for him to come back from the north so i can do some "business" (CAR RELATED) with him..
  12. #72
    Junior Member Backyard Mechanic Sigmeister's Avatar
    big hunch here, but what is the rev limiter set to on a 6 cylinder soarer?
    on commos i think they get their signal from the dash/instrument cluster to a multiplier then to the computer. so if one changed an instrument cluster from between a 6 cylinder version to a v8 version the multiplier for revving the engine would be different.
    this is no commo i know but it is just another theory.
    debunk as required
    good luck.
    Classic JC Quotes
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
    "Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
    "The Mitsubishi 3000GT is about as sporty as a game of Darts."
  13. #73
    measure the frickin inputs and outputs and you will find your answer
    there is no need to guess.. just fix it
  14. #74
    It has been suggested thet the Throttle Position Sensor may be at fault. What is the part number on the sensor closest to the manifold and the sensor on the traction control butterfly farthest from the manifold?
    Jealousy is a curse
  15. #75
    i wouldnt get out of beer for a slab of beer
    and by looking at length of thread its not goin to be that easy
    id atleast want a very big bottle of jim beam
    anyway im off to goto qld in few days to wire up 3 1uzs
    if yr interested in fixing it then call me
    maybe ill have my phone on if i can be fuct lookin at it
    heheheh
  1. Urgent KE70 Help Needed
    By KEBOOM in forum Tech and Conversions
    Last Post: 25-05-2006, 05:52 PM
