Results 1 to 8 of 8
Thread: 4agze -> 4agte Alternator Alterations
    Default 4agze -> 4agte Alternator Alterations
    Hey all..
    almost complete in finishing my turbo project from 4agze -> 4agte..
    in regards to the alternator.. as it hangs off the front of the engine on a 4agze..should i get the 4age bracket from a n/a 4age and swap the mounting position..
    or just measure the belt up and order one from a place like global auto parts?
    Cheers..
    GTZ
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    Default Re: 4agze -> 4agte Alternator Alterations
    change the alternator bracket. Thats what i did, so its now on the otherside of the motor.
    Homebrew, triumph triple, turbo aw11
    what? Automotive Encyclopaedia EVOSTi's Avatar
    it will be neater to change the bracket, but im using the original bracket and running a smaller belt which runs on the wrong side of the idler pulley, a bit ghetto but it wouldnt be easy to change the bracket it my instance.
    Quote Originally Posted by EVOSTi
    why isnt it easier in your case?
    cause im running my dodgy CAS where the alternator would be, not running factory CAS cause turbo mani would hit it.
    I'd say swap the mounting position so that if you break a belt when your away, or something similar, it should be a little easier to source!
    ([][][]II--LT--II[][][])
    it shouldnt be hard to source anyway, i dunno what car the belt thats used comes off but its probably no less common than a gze.
    IMO changeing the alt mount to the inlet side is the better thing to do, cleans up more space for turbo stuff.
    though.... as well as the lower ge alt mounting bracket, you need the water outlet from the head of a ge as it has the 2 bolt holes for the top alt tensioning bracket (plus that tensioning bracket), then you will also need the water pipe that runs from the top head outlet accross the rear of the block as it's different to a gze one. this pipe needs (well i did) modified so it doesnt run on the knock sensor, i just cut it shorter and put a peice of heater hose in between to direct it around the knock sensor.
    also i am not 100% sure a gze alt will mount on the inlet side with the ge gear.... i use a Bosch 120amp universal alt.
    that's all i can remember at the moment.
  1. 4agze to 4agte worth it?
    By rollamattae86 in forum Tech and Conversions
    Last Post: 10-06-2009, 04:08 PM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  3. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  4. 4agze conversion
    Last Post: 02-03-2006, 08:52 PM
  5. 4AGZE Tech info
    By puzzle man in forum FAQ
    Last Post: 04-02-2006, 01:13 AM
