Results 1 to 3 of 3
Thread: Intercooler shape/size
    Cool Intercooler shape/size
    Hey guys!
    My project car - ae86 with a 3sgte, turbo - gt3040r.
    Now before I had the 3sgte, I had a 4agte and was planning on a vmount intercooler/radiator setup.
    I currently have a 510x150x76mm intercooler - long and thin, which I will be able to nicely fit for the vmount setup.
    I'm abit worried as to how this will perform now..
    Can anybody tell me what the diffrence is in having a long thin intercooler like mine, as opposed to say a more 'normal' 450x300x76mm intercooler?
    My guess is more pressure loss at high boost, but similar heat exchange rate..
    From rough measurements of my current 'long thin' intercooler core:
    Each tube has volume 8 x 510 x 76mm = 310cm3
    Core has 8 tubes so Total Volume = 310mm x 8 = 2480cm3
    Compared to a 'normal' 450 x 300 x 76mm core:
    Tube volume 8 x 300 x 76mm = 182cm3
    Core has 16 tubes so Total Volume = 2912cm3
    Both intercoolers have similar volumes, so I'd assume similar heat exchange capabilities..
    However... Air entering the intercooler has 8 tubes to go through in the 'long thin' design, compared to 16 in the more 'normal' design...
    I'm at a stage where I'm ready to get a radiator made.. so need to decide, stick with the original planned vmount with a long thin intercooler?
    Or go with a front mount setup, and get a 450x300x76 intercooler?
    EDIT: btw, planned boost will be low initially.. around 5psi.. But I would want an efficient setup being able to run say 20psi should I get bored with 5..
    Jun 2006
    Default Re: Intercooler shape/size
    What is the flow area of your cooler, being the size of the tubes the air flows through?
    Rough rule of thumb for the minimum flow area (tubes that air flows through) for bar and plate coolers is 50square cm per 100 hp, and 30square cm per 100 hp for tube and fin coolers.
    The cooler you require for 5 psi will be a lot different for 20psi, with higher boost you will be flowing a lot more air so tube area will need to be bigger and trying to get riud of a lot more heat so heat exchange area needs to be bigger.
    Generaly more tubes and shorter run length will give better overall efficiency.
    regards
    jon
    Quote Originally Posted by jonra23
    regards
    jon
    what he said...
    same internal volume must have same residence time.... but more tubes = less air resistance
  1. Intercooler setups
    Last Post: 16-08-2006, 11:08 AM
  2. 4AGZE Intercooler and exhaust suggestions?
    By DavisJD in forum Tech and Conversions
    Last Post: 07-02-2006, 05:20 PM
  3. cheap intercooler piping (exhaust pipe)
    By love ke70 in forum Tech and Conversions
    Last Post: 03-02-2006, 05:16 PM
  4. Legality of cutting front to mount intercooler..
    By d-shiznit in forum Tech and Conversions
    Last Post: 21-12-2005, 10:15 PM
