Step 4:
You can either go two ways here:
1 is: Simply unplugging the various speedo cables, craning down and undoing the wires on the bell.
2 is: Removing the top metal shield and entire dash cluster which is what I have done. To remove the metal shield, by now it should just be 2 x 10mm nut holding it on. After that is removed you will need to unplug the 3 x plugs on the back of the dash. These simply have press down clips to remove. The same applies for the Speedo cable except the clip is on the side.
Step 5:
Remove the 4 x screws holding the dash cluster in on the front.
Step 6:
Is unscrewing the Bell Relay off the back of the Dash Cluster.
Step 7:
Think of inventive ways to take revenge upon annoying Bell Relay![]()
Step 8:
Reverse all the steps for the reinstallation of your cluster and dash. I hope this has helped out, I know that the BGB and a few other manuals don't tell you how to do it and the whole ding dong on a 4 hr trip gets really frikkin annoying.
Enjoy!![]()
