You can get custom King springs made if you like, they can be ordered from Autobarn, and arent that much more than a normal set. You can easily change over rear springs yourself, all you need is a jack, a pair of axle stands and a 14mm spanner/socket.
Raise rear end via diff, put axle stands under the subframe in front of rear wheel well, undo the 14mm bolts on the bottom of the shocks and remove lower part of shock from diff housing, lower diff until springs are loose (removing wheels will help), remove old springs, install new springs, then raise the diff till the shocks will go on, put them on, do up the bolts, raise till off the axle stands, remove axle stands, install wheels, lower car, drive away.
Shouldnt take more than half an hour if you have a hydraulic trolley jack (cheap from Kmart). In fact it would be cheaper to buy the gear yourself, and the tools, and do it yourself. Can be done on the side of the road if required.
Shocks will be a bit trickier, get somebody to hold the upper sleeve (under the car) while you undo the top nut (beside fuel tank, inside boot). Quite easy to do while you are swapping the springs. Should require 17mm spanner.
