Results 1 to 3 of 3
Thread: ke70 tacho issues. one for the electronics people
    Default ke70 tacho issues. one for the electronics people
    hey there
    ive searched so dont bother telling me to go do that
    im trying to get the stock 4cyl tacho in my ke70 to work with the 6cyl 1ggte
    now i know all i need to do is put a trim pot in and adjust until it reads right
    simple right..
    well NO!
    first up, im using a mallory ignition system so the tach signal comes from that, not the coil. so ive taken a wire, looked on the back of the cluster and worked out which one i believed to be the correct wire for the tach signal
    connected that
    started car
    (the trim pot is already in)
    tacho no worky
    play with trim pot no good
    right
    measure resistance on trim pot with muilti meter set on 20K ohm it stays on 0.05. thats not right
    disconnect trim pot, adjustment now works fine
    weird i think
    so i think, right start car tacho should work
    oh no it fucking doesnt...typical
    so im now at a dead end
    has my tacho raped itself?
    have i used the wrong pin. if anyone knows for sure which is the right pin in the ke70 wiring that would be great
    ive used the black one in the plug closest to the drivers side. it looks the right one
    one other thing, i attached the 2 wires for the trim pot just before the tacho rather than on the board, should this cause it to fuck up?
    not that it would stop it working once i disconnect the trim pot :S
    also, theres no resistance across those 2 wires even when removed from the trim pot
    so WTF?!?!?
    theres my brain dump
    please help
    Default Re: ke70 tacho issues. one for the electronics people
    oops, turns out the tacho was sticking...someone pulled on the needle and that makes them stick a bit
    hehe
    now ive lost boost grrr :@
    Junior Member 1st year Apprentice WeekendWarrior's Avatar
    new south wales
    u mite need check that it is working right because 4, 6, and 8cylinders run off a different pulse rate.it seems odd that it would be working normaly but hey if it works it works
    - Project "BILLYGOAT" the ta22 found on the edge of a hill
    BEARCON All your construction needs 67 624580
    THE CELICA SHOP COMING SOON
  1. Tacho tech
    Last Post: 04-08-2009, 04:10 PM
  2. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
