Results 1 to 6 of 6
Thread: mx83 conversion help
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    Default mx83 conversion help
    Alright i need help with my 1jz jzx81 halfcut wiring into my mx83 cressida and im looking at taking it to some one to do as i dont have the time to work on it with work and all and i need to get it back on the road
    ok car is using full jzx81 wiring the dash is jzx81 dash so everything pretty much is jzx81 sept the rear of the car all the dash lights work dont no about aircon have not connected it to test it (controler) sunroof works gauage cluster works digital one lights work indecators dont
    anyway way the problem is when i go to turn it over everything cuts out gauages and lights turn off then once i put it back 1 it all fine agian
    has anyone got ideas what it could be? or a good place to take it or want to do it for me
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Default Re: mx83 conversion help
    Freight the Car to Sydney
    Get Sideshow or Mos to wire it up
    You can borrow my driveway/garage for it
    Fly up and drive it home...
    Sideshow quotes $650 for a 1JZGTE
    Montrose
    You can probably get someone a little more local to take a look at it for you.. Whereabouts do you live?
    May 2006
    i live in cheltenham vic people who dont know where that is think southland shopping center
    yeah i was thinking that southo but want to see the local area 1st if worst comes to worst i will have to
    so you've done the troubleshooting disconnecting everything to the rear of the car apart from the fuel pump wires?
    If so I'd be checking the starter circuit next including the starter relay and the NSS bypass that was done in japan.
    NO probs,
    I am off work at the moment, so if you want to do it, let me know... I am at home, bored shitless...
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 09:38 PM
  2. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  3. MA70 --> JZA70 Conversion
