Results 1 to 5 of 5
Thread: AE101 ZE brake upgrade to AE92/AE93 - rotor reduction amount?
    Bodgepro Mechanic Grease Monkey Ghetto-Spec .:bayka:.'s Avatar
    Default AE101 ZE brake upgrade to AE92/AE93 - rotor reduction amount?
    Hi Guys,
    I am just about to fit ae101 4agze twin piston front calipers and larger rotors to my ae93 sx. The larger rotors will need to be shaved down a little to allow the calipers to bolt up to the existing hub mounts.
    Does anyone know the final diameter that the ae101 rotors should be reduced to, that allow calipers to bolt on to ae92/93?
    Have other ppl got around this without reducing the rotor size? i.e. somehow extending the mount point for the calipers.
    Default Re: AE101 ZE brake upgrade to AE92/AE93 - rotor reduction amount?
    I'd actually take it down to 260mm.
    I've had 3 sets done to 260mm now, one set was a little bigger and the edge of the disc was on contact with the caliper, so had to get the disc machined down again.
    Thanks guys!
    I went for 263mm and have no issues (and less than a mm clearance) But then i tend to chase every last 1%, just cause it bugs me when i know its there and i haven't got every last bit.
    You really should be fine with 262, if it needs to be right 1st time drop a mm or 2, but 1mm is a bit in terms of rotating clearance.
    Toymods Club Member
    By The Witzl in forum FAQ
  2. Celica Brake Upgrade
    By fuzz! in forum Tech and Conversions
    Last Post: 21-05-2014, 12:33 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. GX71/MX73 brake upgrade, the easy way...
    By Soarer21 in forum Tech and Conversions
    Last Post: 18-12-2005, 11:15 PM
