Results 1 to 9 of 9
Thread: help needed manifold gaskets? type and were to get
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default help needed manifold gaskets? type and were to get
    im looking for a multi-shim type manifold gasket gor a 1ggte
    anyone know if there is anyone in aus who makes multilayer gaskets
    or failing that where can i get std 1ggte ones
    Default Re: help needed manifold gaskets? type and were to get
    you can get a 1g gasket kit, which comes with every gasket copper washer o ring for the whole motor from toyota, from memery they were about $450, delivered too your door, very worthy i wouldnt build another motor without one, even comes with new o rings ect for the injectors.
    you can get a triple layer metal head gasket from performance wholesales in brisbane too
    cheers steve,
    1ggte, 11.22 @122mph
    if the ex manifold (this is for a exhaust manifold?) and head faces are both true, then Copper Maxx will do fine for the gasket.
    cheers ... all i want is the exhaust manifold gaskets
    coppermax?? ..... is that a gasket sealer?
    i think i will need a gasket of some sort as im using a stainless tube manifold not the std cast one so the face is not going to be absolutly perfect
    Default
    duplicated message ????
    Default
    Default
    yea a silastic gasket. Loctite Copper Maxx is all i use on my head to turbo manifold, manifold to turbo, turbo to dump pipe and exhaust flanges.
    dont know what happened there..... it all jammed up!! and my reply got posted over and over
    if i get stuck ill give it a go i have used similar stuff b4 on turbos but was never sure how reliable it would be long term
