Results 16 to 27 of 27
Thread: Jaycar Interior Light Delay Kit - Help
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Default Re: Jaycar Interior Light Delay Kit - Help
    Quote Originally Posted by Dale
    But how does it provide the earth when essentially it's tapping into the same earth that the door switch controls - so once the door is closed, the switch is pushed in and the earth disconnected. Seeing as the earth runs through the same cable, isn't the switch a physical thing, so in theory there would no longer be an earth there for the jaycar unit to continue using?
    I have a feeling I'm missing something with all this, like I said it was over a year ago I installed these!
    I believe this is what theChuckster is meaning....
    What happens is when the switch is closed, the light is earthed and we have light.
    When the switch is left open, the light then receives it's earth through the jaycar kit, which leaves this earth open for a certain amount of time. When that is finished the kit then simply switches off and the light has no earth at all, therefore it is off.
    Still begs the question as to what the hell is wrong with mine lol!
    Sorry, I'm more with it now. I had a feeling that the jaycar kit had it's own earth? If so then it all makes sense to me, I was mixed up in thinking that it didn't.
    I am the sun
    Quote Originally Posted by ndgcpr
    Yeah i also built one of the older ones. I am north bris if you need a hand.
    Does the led light? If not your mosfet could be the wrong way around.
    I do not believe there is an LED in the system... I have tried a new mosfet in the opposite orientation. I have also tried a new optocoupler in a different orientation... made the FET heat up like all hell. I actually installed a socket for this so I can pop in a new optocoupler in without having to solder it over again.
    When the jaycar kit is pluged in and the switch is turned off, I'm getting basically 0 voltage reading over it's + and - terminals.. this right?
    I'm going to try to plug it into my ST162 or my sisters ST184 tonight and see if that works, but I can't see how plugging it into an actual car rather than a simple 12V circuit with a light and switch will make it differ.
    The only thing I haven't replaced is the bridge rectifier, however I don't think this would affect what I'm doing at all... I don't currently have the tail light circuit hooked up, I did not think this would make a difference as per the circuit diagram, it seems like a completely seperate circuit. I have however put voltage through the tail light circuit to see if it cut out the lamps at all, but no result.
    Junior Member Backyard Mechanic Kagetsu's Avatar
    NT
    Just seems overly complicated for what should be a relatively simple design.
    If the Jaycar unit senses the Tail light circuit and chooses not to work when it is on (per the Chuckmeister), may that not be the problem you are having with not installing it in a real car?
    I guess I am trying to say that a lack of a tail light circuit may not be the same thing as sensing that the tail light circuit is not operating. If so, then your kit is working because it just hard shuts the light off.
    Um, just a thought.
    door switches earth the switch housing to the body and have a single +ve wire out the bum.
    opening the door completes the circuit hence turning on the light.
    with this in mind my idea is this
    hook jaycar positive to door switch positive (all door switches should be daisy chained)
    hook earth to body somewhere.
    im assuming the kit fakes the door open signal to trip the light and doesnt need to be connected to the actual wires leading to the light.
    Edit: just re-read the thread and found ive said nothng new
    Black Betty >HERE!<
    (\__/)
    I will try that, however I'm not even using a door switch to test it, i'm using a normal old switch... perhaps that has been my issue all along... i don't know... like I said I'll try and install it in my ST162 soon and see if that brings along any progress... I thought that the tail light circuit might not need to be connected seeing as from the circuit diagram, that section looked seperate... however I will try it out anyway and see what happens. Thanks for all your ideas guys I'll have to dose out some pos rep.
    there ya go .. theory and practise ...in theory there the same
    Black Betty >HERE!<
    (\__/)
    Well I hooked it up to the ST162... didn't even need to hook up the brake light circuit and it works fine... obviously there was some variable there in my fake circuit that I didn't take into account... of course this means I'll need to find some door switches and work out the wiring in the RA23 earlier than I anticipated, but at least I know my circuit it correct. Thanks for the inputs guys, + rep for all!
    Junior Member Backyard Mechanic ndgcpr's Avatar
    Quote Originally Posted by Major Clod
    As yes sorry i missinterpreted the diode. Good to hear it is all fixed. One thing to note though is that i installed one of these onto my mates 180. It used to stuff up the alarm so we removed it. whenever the alarm was activated it would turn on the delay kit, which would simulate the door open and the alarm would complain. Maybe that is what they fixed in the new revison...
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Quote Originally Posted by TA-022
    hook jaycar positive to door switch positive (all door switches should be daisy chained) hook earth to body somewhere.
    actually - door-light switches are in parallel - daisy-chain infers some kind of serial connection.
    yeah realised my bad wording .... redid my dash loom today and notice the wiring is parrallel.
    Black Betty >HERE!<
    (\__/)
  1. Using Jaycar Rev limiter as "valet mode"
    Last Post: 17-04-2006, 11:33 AM
  2. Jaycar temperature switch
    By Big rob in forum Tech and Conversions
    Last Post: 17-02-2006, 09:10 PM
  3. ??? Power window delay for old Toyotas
    By Drifty Midship in forum Tech and Conversions
    Last Post: 08-02-2006, 08:10 PM
