Results 1 to 8 of 8
Thread: Diff Identfication(Visual)
    Default Diff Identfication(Visual)
    Hey all,
    I was wondering if there are easy ways of identifying Toyota diffs from the outside, I am not sure what diff my celica has, its a TA23, but it has had an engine conversion and I am not sure if the stock T series diff was retained. When I had it up on the ramps it looked as though the welds may have been an aftermarket jobbie, but I have never seen the stock ones, so I am not sure. I will attempt to get some pics up, but any ideas would be useful.
    Default Re: Diff Identfication(Visual)
    Quote Originally Posted by WindeX
    Hey all,
    the only upgrades i wopuld think of are:
    F series corona diff - would have drums
    Bogwarmer from a commodore - have discs
    G series (if ur lucky!!) - would have drums.
    User Conversion King
    NWA
    Quote Originally Posted by Robbos_Toyotas
    ahh it all makes sense now.....
    all disk brake live axle diffs are originally from commodores and all drum brake diffs are either F or G??..... awesome info
    pull an axle out and count the teeth on the spline.....not a difficult task.
    is the diff front or rear loading.
    ie commodore spec or ford 9" (and toyota) spec ???
    T series are 23 spline
    Fseries are 27spline
    G series are 31 spline
    hello
    Grouse, I guess its time to take the wheels off this sucker... now wheres key to the lock nuts I have on my godamn wheels.
    Quote Originally Posted by brett_celicacoupe
    g series are actually 30 spline.
    I had a look around the web and couldent find any really good exploded views of diffs, I was am assuming that the splines are the teeth on the end of the axel? Am I correct in this?
    Yes you would be correct in this assumption.
    Grouse, thanks for confirming that dude.
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  3. jza80 diff mounts into the diff cradle ???
    Last Post: 08-05-2006, 01:35 AM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 09:13 PM
