Results 1 to 9 of 9
Thread: Resealing a sump
    Aug 2006
    Question Resealing a sump
    Hi All,
    I need to reseal the sump on "old faithful" (SV21 Camry, 3S-FE).
    Does anyone know the correct sealant that needs to be used on these?
    I asked at the local Auto Shop, however the guy had this "I don't know what I'm talking about" look on his face, which didn't exactly thrill me....and I'd hate to do it and have it leak again.
    Appreciate any help,
    Andrew.
    Default Re: Resealing a sump
    if rubber, usually a sealant is not needed, except at corners where there is a joining metal piece (ie timing cover etc). a thin smear of silicon (black oil resistant) can be used,
    BUT if you overtighten when the silicon is not cured, you can actualyl split the rubber and it will be stuffed.
    put on smear of silicon, tighten up to contact and maybe a _fraction_ more, then wait a day or two for the silicon to cure, then tighten to spec.
    perth
    if you wont good thick silicon glue the "nissan" "red" shit is fuking fantastic you get them with the gasget sets or u can by seperate. nissan did one thing rite hehe
    sv21 is just glue im prety shaw.
    Aug 2006
    Smile Re: Resealing a sump
    Thanks for that, now I know what to ask for.
    F.Y.I. The camry does just have silicone, there is no actual gasket.
    Cheers.
    oh, in that case, disregard my post
    what does toyota use? some thick oil and fuel resistant silicon?
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Quote Originally Posted by fixeruperer
    Yeah I've that stuff too, pretty much the same as V V V
    Loctite Hi-Temp red silicon is good stuff, just make sure both surfaces are oil free.
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    yeah the toyota thick silicone is good too!
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Yeah the 3S-FE uses no gasket for the sump, and I think that goes for the whole line of 3S engines. My old 3S-GTE didn't have one either, and all I sealed it up with was the Toyota factory black goo which works a treat.
    edit: actually there's a few different types of Toyota goo which you can get, I know there's the Toyota Red (for gearbox applications) and the Toyota green as well (for coolant / water-based applications).
    TRIKKE | Video
    ThreeBond Gray
  1. Sump position model guide (SPG#)
    Last Post: 31-01-2006, 01:15 PM
