Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 136 to 150 of 188
Thread: late 97 on hilux 3rz turbo conversion walk through
  1. #136
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Default Re: late 97 on hilux 3rz turbo conversion walk through
    Those are some good numbers rodi, Touch wood i hope top break 400hp with mine once its built
    Good note. Caltex has started to sell e85 fuel in qld.
    ALEXANDRA HILLS, Cnr Finucane Rd & Cambridge Dr
    WORONGARY 1 Mudgeeraba Rd
    BROOKWATER, 7001 Augusta Parkway
    SOUTHPORT 152 Smith St, cnr Kumbari Ave
    MACKENZIE 1015 Mt Gravatt-Capalaba Road
  2. #137
    Junior Member Backyard Mechanic rodi's Avatar
    Apr 2007
    i,ve been trying to get the torque up more than power because its now auto, changing diff gears as the ones in there give me a top speed at 6500 of 307kph and having a bit of trouble getting of the line, on the dyno it looks like the back doors are trying to open, at least i stopped it breaking 3rd gear
  3. #138
    Nov 2008
    queensland
    what transmission you using?
    Cos no doubt it will be the next thing to be changed after the lsd is fitted
    Id like a auto box as its a daily driver and more of a straight line go to whoa kinda car
  4. #139
    Apr 2007
    box is a a340 out of a 1jzgte soarer which i then fully manualised, very easy fit up, 3rz auto bell housing
    3rz flex plate, 1j torque converter, 1j box, speedo is easy but tail shaft is a bit of a prick, valve bodies, converters are available, still no tunnel mods
  5. #140
    Nov 2008
    queensland
    sounds alot easyer then a r154 conversion,
    Whats the problems with the tail shaft?
  6. #141
    Apr 2007
    i had to buy a yoke and hybrid uni from hardys about $170 but my shaft is ford v8, might be easier if its all hilux but you have to shorten it 100mm, boxes can be bought for $300, $40 to manualise, i got $650 for my last W58 so not to bad
  7. #142
    Jul 2010
    queensland
    hey berad and other 3rz turbo guys
    I got a quote for a supply n install on my 02 hilux 4x4, he wanted to know if i wanted a custom plenum made up.
    i would like to have my luxy around the 320-350hp mark
    My question is, would the stock toyota plenum be more than enough to use? Instead of using a custom plenum (extra $990).
    Is there a rule of thumb like anything over 450hp then you would use one?
    Does anyone know if theirs much turbo lag difference between a stock plenum and a custom one?
    I will be keeping the bottom end stock for now, my lux has done about 170,000. The guy will be putting in a cometic head gasket while he has the manifold pulled off.
  8. #143
    Nov 2008
    queensland
    My recommendation is wait to see what the intake temps are first, If they are high then do a plennum.
    If he's doing a cometic head gasket then he should be putting a set of arp head studs aswell.
  9. #144
    Apr 2007
    First dibs on whats left of the block
  10. #145
    Nov 2008
    queensland
    leg out of bed?
  11. #146
    Apr 2007
    Hey TWEAK can you tell me if you can see heat transfering down your damaged rod from the gudgeon pin/ little end please, and yes there goes another one
  12. #147
    Nov 2008
    queensland
    Still waiting on my engine to get built. I'll see if i can drop in some time during the week and grab the rods
  13. #148
    Nov 2008
    queensland
    Quote Originally Posted by rodi View Post
    The a340 tranny seems like a common thing amoung alot of makes........... even jeep has it lol
    So if i decide to go down the a340 route what would i need electronically?
  14. #149
    Apr 2007
    http://www.toymods.org.au/forums/showthread.php?t=54880
    try this, forget the wiring colours but it basically is right, all up cost is about $25
  15. #150
    Jul 2010
    queensland
    hey tweak i cant send you pms? dunno why? theirs nothing in my sent box
  1. Travs 3SGE +turbo RWD conversion
    By TRAV-KE55 in forum Tech and Conversions
    Last Post: 08-09-2010, 07:50 AM
  2. SW20 MR2 turbo conversion
    By GaMMa in forum Tech and Conversions
    Last Post: 27-02-2007, 11:38 AM
  3. difficulty Manual conversion in late model chaser or aristo
    By 73ta22 in forum Tech and Conversions
    Last Post: 25-07-2006, 02:33 PM
  4. SV21 Camry + Turbo Conversion.
    By UltraViolentRay in forum Tech and Conversions
    Last Post: 15-03-2006, 08:29 PM
  5. turbo conversion on ae112rlevin
    By mrxplode in forum Tech and Conversions
    Last Post: 13-02-2006, 02:08 PM
